99 coupe alarm/door lock issue need help asap
Old Nov 19, 2005 | 06:00 PM
BROKE.eg's Avatar
Default 99 coupe alarm/door lock issue need help asap
ok my freind has a 99 civic that already has power door loks.He is trying to install an alarm. He disconected the factory keyless entry/alarm so he can hook up the after market one. Now the door lock switch inside doesnt work and we can get the alarm to activate the door lock either.
i have no idea what goin on with this car. plus it only has one wire coming from the passenger side door under the dash.
Old Nov 19, 2005 | 09:06 PM
fcm's Avatar
fcm
Old Fart
Default Re: 99 coupe alarm/door lock issue need help asap (BROKE.eg)
LOL. you can't remove the "Keyless entry module" [the white unit in the drivers side kick panel] the connections from the alarm are made at the plug into the module, green/white is lock and green/orange is unlock, a low currant, [250mA] neg. (-) is all they need to trigger the door lock relays that are in the module. 94
Old Nov 19, 2005 | 09:14 PM
BROKE.eg's Avatar
Default Re: 99 coupe alarm/door lock issue need help asap (fcm)
so if he unplugged the modle then it wont work?
Old Nov 19, 2005 | 09:31 PM
BROKE.eg's Avatar
well it sounds like hes screwed then cause he took it out and then cut the plug off.
Old Nov 19, 2005 | 09:43 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
ooo dam. That gonna be a pain and time consuming project the he is about to have.
Old Nov 19, 2005 | 09:48 PM
fcm's Avatar
fcm
Old Fart
If it was the white module in the drivers kick panel yea he is kind of screwed, he will have to reconnect it or install a pr. of SPDT relays on the door lock actuators wires like this http://www.the12volt.com/doorlocks/page3.asp#arp 94
PS, you will also have to connect the green/orange and green/white wires from the door switch to the relays so they work, [same place as the alarm wires]
Old Nov 19, 2005 | 09:52 PM
BROKE.eg's Avatar
looks like its tome to finda a junk yard and get that wiring harness
Old Nov 19, 2005 | 10:02 PM
fcm's Avatar
fcm
Old Fart
That would be the easiest, leave as much wiring on the plug as you can, also if you do that it will be easy to do the drivers door unlock only, [priority door unlock] if the alarm he has has that option. 94
Old Nov 21, 2005 | 08:23 PM
jdmpsicivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BROKE.eg &raquo;</TD></TR><TR><TD CLASS="quote">well it sounds like hes screwed then cause he took it out and then cut the plug off.</TD></TR></TABLE>
yikes
Tharshan
Audio / Security / Video
Sep 30, 2018 04:34 PM
tobytigger
Aug 16, 2012 09:15 PM
buff1110
Apr 17, 2010 05:17 PM
alacard
Jun 7, 2008 03:32 PM
