question about ECU
Old Nov 19, 2005 | 05:54 PM
EDVxRICHARD's Avatar
Default question about ECU
ok i have a 1992 honda civic CX non vtec.......and i am installing a B16........the instruction said i have to add a wire such as vtec is the yellow wit green strip is there a picture or tell me how to add the extra wire or its already there but i have to do something ahahah.....help me out or just give me the link to a thred if its been made
Old Nov 19, 2005 | 06:15 PM
ekb16's Avatar
usually you run a wire from the vtec, knock sensor, etc.. to your ecu..you would need pins to snap into the plugs
Old Nov 19, 2005 | 06:28 PM
Default Re: (ekb16)
run a wire?....does that mean i have to put an extra wire or its there already cau i just looked at me car and it looks like its there and ive notice exrta plugs that are there is that for the VTEC Solenoid and VTEC Oil Pressure Sensor.........do i just pull out the wire from there take out the wire that is on the wiring harness and put the vtec wire where it belongs?.....sorry im tryin hard to understand
and wat do you mean by "pin"
Old Nov 20, 2005 | 08:58 AM
GetawayInMoscow's Avatar
Default Re: (EDVxRICHARD)
what year b16? you might be able to get away with only adding one wire for vtec if it's a jdm b-series 96+
Old Nov 20, 2005 | 02:21 PM
Default Re: (GetawayInMoscow)
it is the motor from here http://hmotorsonline.com/shop/...30004 from wat ive seen from my car it looks like i just plug and play and it should take care of the vtec......am i right?
Old Nov 20, 2005 | 02:40 PM
EGmikeH22's Avatar
* B A N N E D *
a cx didn't have vtec, so there is no wire going into the plug in the ECU where it sends the signal to turn on vtec.
it will not take care of itself.
and a pin is a metal thing that is the connection between the wiring harness and the electrical thing, as in there is a one pin connection at the vtec solenoid and a ~50 pin connection at the ECU.
Straits514
Feb 15, 2011 08:07 PM
mr. carpenter
May 5, 2004 09:47 PM
juicy.koreans.suck
Dec 25, 2001 01:54 PM
