What Ecu For Ek h22swap? preferred or better?
Old Nov 19, 2005 | 04:37 PM
SoySauc3 H22atch's Avatar
Default What Ecu For Ek h22swap? preferred or better?
I was just wondering what Ecu everyone went with on their H22 swaps into ek's. Idk which one I want to use. What measures were taken to adapt the new ecu in. obd1>obd2 conversion harnesses? any obd2 ecu's that can be used in the swap? p2t maybe? idk lost like a ***** Fer on this one... what chips did everyone use also? any suggestions?
Old Nov 19, 2005 | 04:38 PM
Default Re: What Ecu For Ek h22swap? preferred or better? (eLusiveH22 Ek4)
im sure this is posted up somewheres in here but I couldnt find it really lolz
Old Nov 23, 2005 | 10:03 AM
swappedcivic's Avatar
p72 integra gsr is what i have
Old Nov 23, 2005 | 10:17 AM
93civic_sedan's Avatar
JDM ITR here
Old Nov 23, 2005 | 08:27 PM
EGmikeH22's Avatar
* B A N N E D *
for the secondary butterflies use a p72 gsr ecu or a p13 prelude ecu
you can chip the p72, you can't chip the p13 (easily)
and a p28 will work but the secondary butterflies wont get controlled (you'll loose 7hp below vtec)
that guy with the ITR, his secondaries dont work, neither do mine for that matter.
PM me if you want a P13 (chipped already)
Old Nov 25, 2005 | 03:01 AM
Katman's Avatar
if you want to stay OBD2 ecu wise, the ecu you want is the elusive OBD2 US 96 P13 ecu....hard to find but the only US OBD2 prelude ecu that doesn't have an immobilizer.
Old Nov 25, 2005 | 07:38 AM
NXLude's Avatar
you can also buy a p28 (cheapest) and just slap a hondata on it. That will control your secondaries for you.
Old Nov 25, 2005 | 11:54 AM
RotiEatter's Avatar
Ditto
Why do we have so many threads regarding the same issue.
Old Nov 25, 2005 | 01:24 PM
Default Re: (RotiEatter)
idk because there is so many opinions out there i guess? lolz... im a noob so i just typed it in... thx for the help guys.... thinking im gonna go with a chipped p28 from http://www.phearable.net then get it tuned on a dyno... cant wait till the snow comes around here for my ek to slide in lolz...
DA STRIKER
Feb 4, 2011 03:49 PM
1993-eg1
Sep 16, 2008 09:28 AM
DOHC Kid
May 27, 2008 05:41 PM
CaptinMcnut
May 16, 2006 05:15 PM
tolowhb
Aug 11, 2003 03:27 PM
