Timing belt side of motor making ticking/knocking noise...not rod knock...
Old Nov 19, 2005 | 02:47 PM
OMG B16's Avatar
Default Timing belt side of motor making ticking/knocking noise...not rod knock...
Well, my cam gear came loose a month or so ago, i just tightened it. Then a few weeks later my car started to make this ticking/knocking noise. I thought it was rod knock, so my dad came and towed me home (Hes a mechanic, but not a honda mechanic.)
Well we took took my cam gear off that came lose and it had some side-2-side play, so i replaced the cams and cam gears with ITR cams and AEM cam gears. Put it back together, and its still making the same noise.
The noise is coming from somewhere under the cam gears on the side of the motor. It sounds like something is hitting something and the tick increases with rpm. Im going re-check and do another valve adjustment tomorrow.
Any opnions on what it Could be?
Or what i should look for tomorrow while i have the valve cover off?
Problem i was having before this, just incase one has to do with the other: https://honda-tech.com/zerothread?id=1406651
Modified by Sick00SiCoupe at 4:01 PM 11/19/2005
Old Nov 19, 2005 | 02:58 PM
greddy2die's Avatar
Default Re: Timing belt side of motor making ticking/knocking noise...not rod knock... (Sick00SiCoupe)
well first off you should get a real car......
lol.....j/k man, i hope you figure out whats up sorry i cant be any help..im useless i know
Old Nov 19, 2005 | 02:59 PM
OMG B16's Avatar
Default Re: Timing belt side of motor making ticking/knocking noise...not rod knock... (greddy2die)
Give me your Hatch You going out tonight? NVM i'll talk to you on aim. ******.
Old Nov 19, 2005 | 03:22 PM
wantboost's Avatar
Who is Mr Robot?
could be the LMA's. thats what happens mostly... they fail. check them.... pull the cams and push down on the middle rocker.... if it doesnt come back up then the lma is bad
Old Nov 19, 2005 | 04:17 PM
OMG B16's Avatar
Default Re: Timing belt side of motor making ticking/knocking noise...not rod knock... (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">could be the LMA's. thats what happens mostly... they fail. check them.... pull the cams and push down on the middle rocker.... if it doesnt come back up then the lma is bad</TD></TR></TABLE>
Your my hero
Old Nov 19, 2005 | 11:59 PM
murtnabila's Avatar
lma? I know i stupid am.
Old Nov 20, 2005 | 11:07 AM
OMG B16's Avatar
Alright well, this noise is different from before, we took the valve cover off and wa la, the bolts from the aem cam gears were hitting the inner timing belt cover, a few min with the dremel and we got it out, no more ticking..
Old Nov 26, 2005 | 05:28 PM
Cyphear's Avatar
Default Re: Timing belt side of motor making ticking/knocking noise...not rod knock... (murtnabila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila &raquo;</TD></TR><TR><TD CLASS="quote">lma? I know i stupid am.</TD></TR></TABLE>
what are LMA's? and what is the MIDDLE rocker? We know we are stupid
EKJOE
May 16, 2009 09:14 AM
UserX826
10
Feb 22, 2009 02:53 PM
Asahi
Dec 9, 2003 12:15 AM
The-LS
Apr 17, 2003 01:34 PM
Stewie
Jan 16, 2003 07:22 PM
