4x114 conversion...high pitch squeek
Old Nov 19, 2005 | 01:43 PM
A.E Motoring's Avatar
Default 4x114 conversion...high pitch squeek
i just did the conversion i got the rotors turned but didn't change the pads, i didnt think i needed to, they still had alot of life on them, but then i brake there is this loud and squeek, like if i needed to change them, can u guys gie me some info? should i have changed them anyways? i know its come from the front...TIA
Old Nov 19, 2005 | 02:29 PM
Sic_DA_Nine's Avatar
maybe your brake pads are too stiff...
if you bought the cheap stuff at kragen and stuff, they will squeak after minimal use. the pads are still gunna have meat on them but will squeak cuz they are stiff pads..
Old Nov 19, 2005 | 04:46 PM
Default Re: (97dC4)
i didn't buy anything.just got the rotors turned and tht was it
Old Nov 19, 2005 | 05:13 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (SPNFEDEJ)
should have bought pads since u turned the rotors......cheap *** pads or jsut give it time for the pad to wear to the rotors
Old Nov 19, 2005 | 05:54 PM
coquitlamEG's Avatar
Default Re: (SnoFlake)
Always change your pads when you get your rotors turned. Your old pads will have grooves etched into them from the shape of your old rotors. If you put them on new rotors, they could eventually transfer the grooves over to your new rotors leaving you right where you left off.
Old Nov 19, 2005 | 05:56 PM
Default Re: (coquitlamEG)
awww ****, going to buy new pads tomorrow
Old Nov 19, 2005 | 06:16 PM
Redline96LX's Avatar
* B A N N E D *
if anything at all, take some sandpaper to the pad to try to get rid of its grooves. are you using the shims with anti-vibration compound?
Old Nov 19, 2005 | 06:20 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">if anything at all, take some sandpaper to the pad to try to get rid of its grooves. are you using the shims with anti-vibration compound?</TD></TR></TABLE>
yea that too!
H2290
10
Jul 28, 2006 01:56 PM
kornerk12
Apr 27, 2006 01:17 PM
::MYCORD::
Jul 11, 2004 03:00 AM
Ferrell
Apr 2, 2002 07:02 PM
