SiR guys (or USDM guys with an SiR front end)...Question for you.
They use a dual filament bulb, correct? one bulb for both high/low beam? or is it two seperate bulbs? Anyway, i just need to know what the bulb # is, or what the low beam bulb # is if it's like the USDM 88-91..thanks alot!
They use a single beam headlight. The light bulb code is H4. And yes it is double fillament. The down side is that you may have to get it direct from Asia or Europe as the plugs are not the same as USDM H4's.
Donato
Donato
Donato
Donato
hey Mugen, the reason I'm asking is because I'd like to get an HID kit for my SiR front clip. When I ask about them, I need to ask if they have an H4C or an H4H? Everyplace I've looked only has 'H4' listed. Got any help?
Marty
[Modified by MugenEF7, 4:16 PM 3/12/2002]
So i can order just a regular "H4" HID kit and it'll work fine? I don't have the front clip yet, it's on it's way as we speak...but I was going to go ahead and order an HID kit before I blow the money! lol.
these are the two sets i've got them narrowed down to:
http://www.XENONDEPOT.com/index2.html
OR http://www.hitechimportlighting.com/bellofhid.htm
Got any advice? I like the thought of having high/low beam work... the BELLOF kit looks REALLY nice. I think it's just 4000K though, and the xenondepot kit i can get 6000K. What do you think? I like 6000K, but I haven't found any kits that use an H4 bulb
Thanks for the response Marty
Phillips makes a 6000K bulb which i believe they do offer in H4. If your happy with 4000K then go for it. 6000K is bright as hell. I like it bright cuz usually I cant see the floor or too far in front of me too much around here. 4000K is good just for driving and cruising. 6000K someone might try to shoot you for blinding them.
hahaha.[Modified by MugenEF7, 4:33 PM 3/12/2002]
well the BELLOF kit says dual beam kit is like 300 bucks more than the regular BELLOF kit..i knew that it's only one beam...but i have heard that companies are about to come out with a dual beam...so i thought maybe the BELLOF kit already had it. The xenondepot kit uses phillips and they have a 6000K bulb
I think i'll go for that one.. Question though- if it's just one beam, how does it work? when you turn on your headlights it comes on 'low beam'....and if you try to do high beams it just doesn't do anything, and just stays 'low beam'? or how does that work?
[quoteThe xenondepot kit uses phillips and they have a 6000K bulb
I think i'll go for that one..[/quote]yes.. the kit so bright oncoming traffic will see a white dot in their vision for days. hehe
thanks for all the info Marty!!!! I think i'll order the xenondepot.com kit (6000K)...muahaha. So basically what you're saying is that with the 6000K kit i should be fearing for my life?
E-lude78
Apr 20, 2003 04:58 PM
