USDM b18c5..Y1 LSD tranny. what do i order clutch as?
Old Mar 12, 2002 | 12:09 AM
Jonathan_ED3's Avatar
Default USDM b18c5..Y1 LSD tranny. what do i order clutch as?
what tranny do i order the clutch/flywheel for? it's going to be clutchmasters. and is a stage 2 enough for a stock b18c5? i need something soft on my foot with smooth engagement, but that'll hold the poewr. thanks for any info.
Old Mar 12, 2002 | 12:15 AM
CRX-RX's Avatar
Default Re: USDM b18c5..Y1 LSD tranny. what do i order clutch as? (hot_EF)
Cable trans, then you get a 90-91 teg clutch.
Old Mar 12, 2002 | 12:19 AM
Default Re: USDM b18c5..Y1 LSD tranny. what do i order clutch as? (CRX-RX)
yeah..cable trans. if it's a 90-91 Teg...and those are rated at like 140 hp, then i should get at least a stage 2 CM because it'll be like a 55 HP increase. right? same thing with the flywheel-90-91 Teg? Thanks for the help.
Old Mar 12, 2002 | 01:04 AM
DCx2xNV's Avatar
same clutch .... hydrolic or cable they all use same clutches... LS ,GSR , Si tranny same ****
Old Mar 12, 2002 | 06:53 PM
littlebluecrx's Avatar
Default Re: USDM b18c5..Y1 LSD tranny. what do i order clutch as? (VTECxEF9)
No 90 to 91 integra use smaller input shaft, hydralic trans use bigger input shaft only exception is 93 gsr uses bigger input shaft so do jdm cable ys1 trans. If you have a y1 trans you can order a a clutch for a 90 integra cable trans. You can get any upgraded clutch , rps ,clutch masters, act, I love my rps clutch , Jason
Old Mar 12, 2002 | 10:32 PM
Default Re: USDM b18c5..Y1 LSD tranny. what do i order clutch as? (littlebluecrx)
alright........i'm going to get CM stuff...i have a Y1 LSD transmission, and a b18c5. what should i order the clutch/flywheel for? ANY 90-93 Teg, or what? Someone please just tell me a specific year
Old Mar 13, 2002 | 05:08 AM
Default Re: USDM b18c5..Y1 LSD tranny. what do i order clutch as? (dc2jdmhonda)
90 to 91 gets a second vote
Old Mar 13, 2002 | 11:05 AM
alright.......thanks guys. Should a stage 2 be enough to hold it (b18c5)....its going to be ClutchMasters. Thanks.
Old Mar 13, 2002 | 12:03 PM
From: LA, Hawthorne, Alhambra, Monteghetto, CA, USA
another vote for 90-91 clutch..... input shaft is smaller on y-1, only cable tranny that uses the bigger shaft is the ys-1..
Old Mar 13, 2002 | 02:10 PM
xtrafastcivic's Avatar
flywheel any b series
Mag00n
Jun 9, 2005 08:27 AM
Creator
Nov 28, 2004 03:27 PM
Cyber ITR
Nov 1, 2003 12:56 PM
EF'n
Jun 28, 2002 07:43 PM
GEN2 HYBRID
Feb 11, 2002 10:23 AM
