removing engine with trans still in car
I need some help on how to get the engine disconected from the trans. Ive removed all the motor mounts and bolts that posible connect the block to the trans and supported by a hoist but it wont budge its like there frozen together.
is there any tricks to geting it out?
btw. the drive axels and shift linkage are still connected to the trans if that makes a differance and the only thing in the block is crank
the car is a 2000 si
is it even possible to pull the engine off the trans with it all still in the engine bay?
I think you need to use some prybars to seperate them, but i dont know if there is enough room in the engine bay to free the block from the tranny even if you do get them seperated...
6" may be enough, i know you need to slide it off, so youll need as much shimmy room as possbile
remember to work around the trans/block with the prybars, dont just go at it from one spot!
im only pulling the engine and leaving the tranny in place, but is it posible to disconect the engine from the trans with the drive axels still connected to the tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16spaz »</TD></TR><TR><TD CLASS="quote">im only pulling the engine and leaving the tranny in place, but is it posible to disconect the engine from the trans with the drive axels still connected to the tranny</TD></TR></TABLE>
Yes, its possible.. but why? You aren't saving yourself much work, if any.
radiotech
14
Jul 18, 2018 08:46 AM
strategy400
16
Oct 31, 2016 06:30 PM
