Lower Fuel Mileage
I've noticed I'm getting worse fuel milage. My driving habits are exactly the same.
My LS has 64,000 miles on it.
I routinely change my oil, and all other fluids.... however my fuel filter has never been changed. My distributor, rotor, spark plugs, plug wires have never been changed. Would a dirty fuel filter be the culprit?
I can't think of anything else. I'm going to change the oil, transmission fluid and fuel filter later today. We'll see if it makes a difference from teh fuel filter...
Def. time for a tune-up plugs cap and rotor and if you got the money wires.....fuel filter as well....
The fuel treatment **** will aid in removing carbon deposits in your combustion chamber.....the deposits over time will soak up fuel decrease mileage.
check your tire pressures too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Understeer »</TD></TR><TR><TD CLASS="quote">Which type?
Lucas is the only way to go
Ali
Ali
