To all those suffering from the weird "clicking" sound from the front of their R's:
Do you endure an anoying clicking sound from the front of your car? Sounds like dimes clicking together when you load and unload the clutch? I did too until:
I installed a Action 2md clutch. Also replaced the throw out and input shaft bearing. I doubt the source of the sound was bearing related. I bet the sourse of the sound was the springs on the stock clutch plate moving around a bit. Any one have this sound still with a solid clutch disk?
annoying sounds yes.
went away after mikehonda refreshed my tranny
y
shi - who should be sleeping
y
I think we figured out the cause of the clicking here:
https://honda-tech.com/zerothread?id=1376384
davidnyc said "I am not sure how to search to find the multiple threads about this issue, but in each thread I responded that my "clicking" noise was fixed simply by loosening and then retorqueing the axle bolts or just replacing the axle nuts and making sure they are torqued properly. "
I don't get a "clicking" sound, I get a "squeak" springy sound when I depress the clutch. It's a stock clutch with 41,000 miles on it still engaging and disengaging fine, and at this point I only hear it when moving very slowly since the exhaust drowns every other sound out when the car is in motion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface »</TD></TR><TR><TD CLASS="quote">Do you endure an anoying clicking sound from the front of your car? Sounds like dimes clicking together when you load and unload the clutch?
Same exact problem
Same exact problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg »</TD></TR><TR><TD CLASS="quote">I don't get a "clicking" sound, I get a "squeak" springy sound when I depress the clutch. It's a stock clutch with 41,000 miles on it still engaging and disengaging fine, and at this point I only hear it when moving very slowly since the exhaust drowns every other sound out when the car is in motion.
I get the clutch squeak too. I saw a post about in the past but I'm not sure what to search for. It sounds like something is breaking.
I couldn't tell you why, but I had a clicking noise from the clutch pedal a few years ago, and the noise disappeared. There has to be a reason, but I don't know what; nothing changed other than a 30k mile service occurred in that timeframe, but I can't remember when exactly the noise disappeared. Strange.
I get a "thumping" sound when i let out the clutch. Almost like you can hear the ball bearings banging into each other. I think my input shaft bearing is shot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond »</TD></TR><TR><TD CLASS="quote">I think we figured out the cause of the clicking here:
replacing the axle nuts did NOT solve the problem for me.. I just ignore it now..
I used to get the click immediately after releasing the clutch pedal, but now it happens 1-2 seconds after that; I don't know what the hell it is. This has happened since around 5000 miles. I have a full face unsprung Action 1KS clutch, and if anything the sound is more pronounced.
redpeppers
May 15, 2006 01:07 PM
