oxy-acetylene lap welds--need advice
Old Nov 18, 2005 | 10:37 PM
ladius's Avatar
Default oxy-acetylene lap welds--need advice
hey all,
so i've progressed to lap welds now (still couldn't get the keyhole to work on butt welds but oh well).
this photo, i added rod as soon as I saw a "c" form.
this one, at the beginning, i took it slow and let the "c" pool get really big.
I feel pic 1 is the better weld but not sure. what do y'all think?
Thanks.
Old Nov 19, 2005 | 12:06 PM
slowem1si's Avatar
Default Re: oxy-acetylene lap welds--need advice (ladius)
not bad lookin i did all those welds in my oxy-ace. class
Old Nov 19, 2005 | 04:32 PM
KFMRC's Avatar
they look pretty damn good but they also like like butt welds and not lap are you sure there not
Old Nov 19, 2005 | 06:15 PM
spoolude's Avatar
Default Re: (KFMRC)
looks liek theres lack of penatration maybe u shoudl try gapping it out about the widith of the filler metal
Old Nov 20, 2005 | 10:47 AM
Goal_Kar's Avatar
Default Re: (spoolude)
Umm looks like you lack penetration on the bottom plate. All you need to do it focus the heat on the botton plate, once you get the puddle to form, bump torch up a bit to the lap plate and start dipping. The 2nd picture you have some undercut at the begining, which is normal. I would work on the position of the torch and your dipping pattern. The first picture looks better, but I would trust the 2nd one if anything because it doesn't lack penetration to the base plate. I'll post some picture of my welds sometime during the week. Also what gauge filler rod are you using? and with what thickness of the plates? Also for butt, I was taught to gap the plates the size of the filler rod. That didn't work for me so I gapped it slightly closer.
Old Nov 20, 2005 | 08:59 PM
ladius's Avatar
thanks all for the replies. these both are actually lap welds with one plate on top of the other. starting the puddle is the hardest part for me. thanks for the tip goal_kar. i'm gonna try that next time!
fyi, the plate is 14 gauge and the rod i think is 0.16mm.
Old Nov 20, 2005 | 09:41 PM
jaydmcrx's Avatar
Are you preheating the metal? I always heat mine before i weld on it. And it looks like your getting way too hot, from the looks of the bottom plate. nice looking structured bead tho.
turbo95eg6
Jan 16, 2009 08:54 AM
Powered By Garrett
Feb 17, 2007 08:35 PM
ilsimsli
Welding / Fabrication
Jan 29, 2006 06:39 PM
SHystrdyGSRtdy
Mar 10, 2005 08:35 PM
azfab1031
16
Dec 21, 2004 12:37 PM
