Simple's Garage sale... oh yes... its huge
Its a damned junkyard at my place, i need to get rid of this **** man
pics provided upon request... have pics of everything
D16z6 flywheel $10
D16z6 clutch $10
D16z6 pressure plate $5l
92-95 civic HB side skirts $15
92-95 civic stock front and rear sway bars $25
SOHC clutch/flywheels/pressure plates, 2 sets of them, lots of life left $25 a set
(2) 92-95 civic wiper motors, $5 each
92-95 civic DX under dash and cabin harness's $50
92-95 civic shifter with **** $10
92-00 or 94-01 dual bend short shifter $10
92-95 civic head light, passenger side $15
stock 92-95 intake arm and box $10
92-95 civic driver side headlight (projecotr with blue ion) $15
92-95 civic fuse boxes, under hood and under dash $10 each
2 sets stock 88-00 civic springs $10
grey sun visors for EG $5
(3) resistor boxes for turbo $15 each
99-00 civic front bumper, gold $50
92-95 civic sun-roof, all working conditon, relays and everything $50
Honda Main relay $25
(2) EG air bags $20 each
civic grey floor matts $20
(2)SOHC non-Vtec distributors $25 each
countless injectors $4 for 4
(4) SOHC fuel rails $10 each
SOHC crank pulleys, one with PS, one without $10 each
(2) stock civic air boxes $10 each
(2)D series valve covers DX $10
B16 heat sheild $10
(4) ODB1 alternators, (1) odb2 $20 each
(2) D series starters $20 each
(2)B series ODB0 starter $20
B series AC compressor $10
D series AC compressor $10
(2) SOHC throttle cables $5 each
90-93 integra LS cams $20
90-93 guage cluster $20
90-93 headlights $10
90-93 wipers, cruise control, buttons, vents, clock, climate control, etc..
set of stock 6x9 speakers $10
Go Ped X ped with balanced crank, ported head and new piston $300, comes with extra motor parts, and pull start
13/16th's Master cylindar and brake booster combo $15
30/40 prop valve $5
30/30 prop valve $5
15/16th's Master cyindar and brake booster combo (from ABS) $15
ODB1 injector clips $10
AC radiator lookin deal with fan for 92-95 civic $10
2 D16z6 blocks, 1 with crank, both w girdles, some pistons/rods $50 each
2 D16 z6 heads, one complete, one just head $75 for complete, $25 for bare
OEM white civic wing $20
OEM GSR strut bar $15
Broken CF hood for EG (used for making CF plates) $25
D16y7 complete Intake manifold (no injectors) $15
2 LS oil pump's 20 each
SOHC timing belt covers, all of them $10
(2)Slave cylindar trans covers $5 each
GSR power steering pump $20
90-93 LS power steering pump $10
Sirius satt radio antenna $25
(3) sohc water pumps $5 each
(4) PVC boxes from SOHC's $5 each
(4) coolant tubes $5 each 2 with thermo's
EG rear trailing arms with drums $25
EG 4 door trunk struts $5
(3) D series alt brackets
All 4 discs for EG/DC $10
Workin 02 sensor $15
EG rad fan $10
90 teg rad fan $10
2 EG/DC fuel pumps $10 each
99 si engine harness for plugs $10
B series spark plug cover $10
stock 94 B18ls Head complete $50
stock 94 Ls intake manifold $20
GSR girdle and main caps $90
GSR water pump and main seal $20 each
2 d15b7 motors, both came out of running vehicles... but need work $50
2 D series oil pans 1 tapped for turbo $10 non tapped $30 tapped
2 B series Oil pans $30 each
D series axles (cores) $20 for the pair
odb1 B16 distributor $80
B series starter $30
black EG steering wheel with air bag $50
integra GSR front hubs and calipers with A arms and **** $50
2 LS valve covers $15 each, 1 stripped 1 not
GSR power steering pump $15
2 OEM tape decks 1 acura, 1 honda $25 each
Grey EG armrest (all plasitc kind) $20
some Cooloant hoses, lemme know which one you need $3 each
Some inside B series dust covers... i have like 3 $10 each
CX guage cluster $10
sunroof buttons $4
LS fuel rail $5
Ls horns $5
B18a PS pump $15
92-95 Civic stereing wheel/radio brezel (surrounds steering wheel and radio) $10
90-93 teg cluster (auto) $5
Da headlights $5
ill think of more later im sure, its like a ******* junkyard around this place... will trade for LOTS of things..
will trade for
skunk2/cuzco struts or tie bars
LS/Vtec parts
Turbo parts
GSR trans
B series Axles
B series mounts
B series shift linkage
SS brake lines for civic with GSR brakes
general other honda items
Modified by Simple at 8:55 PM 12/7/2005
D16z6 flywheel $10
D16z6 clutch $10
B16 heat sheild $10
30/40 prop valve $5
30/30 prop valve $5
EG rad fan $10
90 teg rad fan $10
sunroof buttons $4
LS fuel rail $5
Ls horns $5
B18a PS pump $15
Da headlights $5
will trade for
LS/Vtec parts
Turbo parts
GSR trans
B series Axles
B series mounts
wondering if you have upper and lower b16 powersteering brackets? if so please email me at egreen00gsr@yahoo.com. thanks
i posted something else but i thought of other stuff.
1. coolant hoses, happen to have upper and lower rad hoses for 94+ teg?
2. visor - little middle visor for EG's with sunroof?
let me know
let me know
