b18c1 block w/ a b16a head
Old Mar 11, 2002 | 09:32 PM
MugenGTR's Avatar
Default b18c1 block w/ a b16a head
This is the CHEAPEST and BEST way to go if you ask me. Question is: Is it easy to do? the head should bolts straight onto the b18c1 block ryte? has anyone done this "cheap" gsr motor? thanx!
Old Mar 11, 2002 | 11:44 PM
skilzz's Avatar
Default Re: b18c1 block w/ a b16a head (MugenGTR)
Just put one together tonight, you should put the b16 pistons on those gsr rods thats a cheap way to raise compression, everything bolts up and this baby runs strong...go for it
Old Mar 12, 2002 | 05:26 AM
MugenGTR's Avatar
Default Re: b18c1 block w/ a b16a head (maddskilzz)
COOL! I'm doing this swap for sure now then. anyone objections or warnings anyone?
Old Mar 12, 2002 | 05:50 AM
Trey's Avatar
25 Year Member
If you just swap the head, your compression will be 9.8
Swap the pistons while your at it. B16a ones are nice and the compression will be higher.
HTH,
slammed_93_hatch
Oct 10, 2007 08:04 PM
skittyscott
10
Dec 8, 2004 04:41 PM
jessevtec
Oct 6, 2003 08:04 PM
Eg6_JDM
Feb 19, 2002 09:30 AM
