Attn: Car Audio / Electrical Gurus
Old Nov 18, 2005 | 03:53 PM
Cav's Avatar
Cav
Default Attn: Car Audio / Electrical Gurus
Im having a few problems i keep blowing fuses, ill explaine my setup
i have 4 guage running into a ciruct breaker style fuse then running to the trunk of my car into a 4 into 2 8 guage distro block. i have tapped into power off of my second amp and running a fuse (its a 5amp fuse ******this is the one that keeps blowing******) then into a bunch of neons and 4 tvs in my trunk. i used to only have 2 tv's now i have 4 in there and the fuse keeps blowing.
which amp fuse should i be using to power these 4 tvs and a bunch of cold cathodile lights.
THANKS!
Old Nov 18, 2005 | 06:46 PM
JustaZC's Avatar
Default Re: Attn: Car Audio / Electrical Gurus (Cav)
You actually do not really need a fuse there. Unless you are running the cable in an unsafe fasion..ie..through more grommets to the outside of the vehicle. The only reason you need to fuse your primary power at the battery is to protect the cable in a shorted situation. But if you have that much hooked up to the second 8ga cable and want to keep running the same fuse configuration, I would recommend adding up the current draw of all the equiptment on that tap. Or just make it easy and go with a 15 or 20 amp fuse. Each TV draws close to 2.5-3 amps and the lights are closer to 2each but that is at full load. This will not keep a screen from self destructing though. You would need to individually fuse each component for that. Hope that helps some...seems like the thread was getting a few looks but no answers..so there you go.
Old Nov 18, 2005 | 08:57 PM
Cav's Avatar
Cav
Default Re: Attn: Car Audio / Electrical Gurus (JustaZC)
thanks man, the tvs have a built in fuse themselves i belive.
anybody else???
Old Nov 18, 2005 | 09:10 PM
nsxxtreme's Avatar
I would definetly keep the fuse. Any power wire over a couple of feet I would fuse. I would also up the fuse rating.
Old Nov 19, 2005 | 11:16 AM
fcm's Avatar
fcm
Old Fart
Default Re: (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">I would definetly keep the fuse. Any power wire over a couple of feet I would fuse. I would also up the fuse rating.</TD></TR></TABLE> Ditto that, just like the "breaker" you have on the 4ga power wire, you need a "main" fuse for the power wire for the lights and screens. 94
Old Nov 19, 2005 | 05:49 PM
Cav's Avatar
Cav
Default Re: (fcm)
i upgraded from the 5 amp fuse that my screens and neons are hooked up to
now i have a 15amp fuse for my screens in the rear, and a 5 amp fuse for the cold catholide lights
thanks for the input guys
on a side note one of my screens started acting up so i made a new wall to hold just the one tv
i got it all going tonight and it looks sweet
Detail2107
Honda CR-V & Element
May 10, 2016 11:15 AM
KING_LIAN
Audio / Security / Video
Feb 3, 2008 04:03 PM
mrdeadman
Feb 21, 2006 04:35 PM
cd5_2NR
Jul 1, 2004 01:38 PM
4doorH22
Sep 6, 2002 07:34 PM
