B-Series Throttle Cable
Old Nov 18, 2005 | 12:58 PM
fasterthenmost's Avatar
Default B-Series Throttle Cable
Is a B-Series Throttle Cable & Catalytic Converter required
to complete a 95 b18b1 swap obd-1 into a 95 civic coupe dx?
Is there any work around?
Someone help me out or sell me one if you have it
laying around and you in the ny/nj/ct area.
Thanks in advance!!!!!!!!!!
Old Nov 18, 2005 | 01:19 PM
DB1_559's Avatar
Default Re: B-Series Throttle Cable (fasterthenmost)
its better if u do trust me it will save u from going crazy
Old Nov 19, 2005 | 05:30 AM
bump
Old Nov 19, 2005 | 06:36 AM
boostedcivicsir's Avatar
Mr. Badwrench
the cable is yes, but the cat i dont think is necessary. use the dx cat.
Old Nov 19, 2005 | 06:41 AM
jdmeg9's Avatar
Default Re: B-Series Throttle Cable (boostedcivicsir)
when i did my b16 in my 93 (they might be the same) i used a del sol dohc vtec throttle cable and used my stock cat with a 99 si header
Old Nov 20, 2005 | 01:46 PM
typeoneeg6's Avatar
Default Re: B-Series Throttle Cable (jdmeg9)
u nedd a 94 ls throttle cable. im sure 94-01 would work. but hasport says 94 ls throttle cable. and i would just get a high flow cat. that dx piping is probably 1 3/4 in so itll probably choke off the new engine.
atlballazz06
Nov 2, 2010 01:43 PM
98CivB18C
Sep 21, 2008 05:14 PM
akteamster
Nov 10, 2005 08:35 PM
Se-rv-Tak
Dec 10, 2003 12:15 PM
Eg6LazyPt
Apr 22, 2003 11:28 AM
