Aftermarket Timing Belts?
Old Nov 18, 2005 | 10:07 AM
KnowForever's Avatar
Default Aftermarket Timing Belts?
Well, i'm about 20k past due on my timing belt/water pump service And my tensioner is making a nice amount of noise so i'm getting pretty anxious to change it ASAP
I'm planning to in the future to either have a JRSC or a Buddy Club Spec 3+ or Toda B or C setup so i'm wondering about a upgraded timing belt. I know with the cams i should definatly have an upgraded belt but would a stocker be ok on the JRSC? I'm probably just going to go ahead and get a PE or greddy belt since i'm still on the wall of what setup i'm going for but i would like to hear some opinions/experiences.
Old Nov 18, 2005 | 10:13 AM
white rocket's Avatar
Default Re: Aftermarket Timing Belts? (KnowForever)
PE timing belt here and no problems whatsoever.
Old Nov 18, 2005 | 10:15 AM
98 Spec R's Avatar
I have see the stock belts used on 600 hp turbo cars with no problems. The OEM Timing Belt will work fine on your all motor setup or a JRSC setup.
Old Nov 18, 2005 | 10:27 AM
K20DC2R's Avatar
Default Re: Aftermarket Timing Belts? (98 Spec R)
i've heard that the stock timing belts work just fine...i hear the toda belts snap without any warning and for no reason....thats just what i heard.......stock belt is the way to go imo.......
Old Nov 18, 2005 | 10:51 AM
Jowee's Avatar
Default Re: Aftermarket Timing Belts? (K20DC2R)
OEM Honda is the way to go.
Old Nov 18, 2005 | 11:40 AM
92TypeR's Avatar
FSAE
Default Re: Aftermarket Timing Belts? (Jowee 1162)
Seen the Greddy belts hold up well. OEM seems to get the job done just as often. Its up to you. I've never heard of the Greddy belts failing.
Old Nov 18, 2005 | 12:00 PM
7k rdlne's Avatar
Default Re: Aftermarket Timing Belts? (92TypeR)
i have always had good luck with oem
Old Nov 18, 2005 | 01:56 PM
itralex's Avatar
Default Re: Aftermarket Timing Belts? (7k rdlne)
Running the OE belt in my motor with M22x cams and Toda Valvetrain
Old Nov 19, 2005 | 05:03 AM
Pondus's Avatar
Default Re: Aftermarket Timing Belts? (itralex)
Toda C and PE belt here, and previously had a PE belt on the stock engine. No problems at all so far, my way of looking at this is that it may not be absolutely needed, but it's not that much more $ compared to a stock belt and if it offers a little peace of mind then that's good enough for me. A rebuild is a LOT more expensive than a Toda, Greddy or PE belt. Oh, and with more aggressive cams I would also change it more frequently than the OEM service interval, for the same reasons as already mentioned.
Old Nov 25, 2005 | 10:09 AM
Default Re: Aftermarket Timing Belts? (Pondus)
I think i'm just gonna go OEM for now, mainly because of the awesome deal Len has going on right now
Old Nov 25, 2005 | 10:10 AM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KnowForever &raquo;</TD></TR><TR><TD CLASS="quote">I think i'm just gonna go OEM for now, mainly because of the awesome deal Len has going on right now </TD></TR></TABLE>
FYI the amount of troubles people have with toda cams and timing belts seem to occur irregardlessly of brand of belt.
Old Nov 25, 2005 | 10:12 AM
Chris F's Avatar
Default Re: Aftermarket Timing Belts? (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">FYI the amount of troubles people have with toda cams and timing belts seem to occur irregardlessly of brand of belt.</TD></TR></TABLE>
That's how it seemed to me too.
If you go OEM, you'll be fine with the JRSC, and if you get cams later you may want to get a new belt then anyway
&lt;--Chris, who's only timing belt failure was when it caught fire. OEM belts are not fireproof.
Old Nov 25, 2005 | 06:50 PM
DvD3's Avatar
B A N N E D
greddy
Old Nov 25, 2005 | 07:21 PM
Dr Pooface's Avatar
Default Re: Aftermarket Timing Belts? (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
&lt;--Chris, who's only timing belt failure was when it caught fire. OEM belts are not fireproof.</TD></TR></TABLE>
You should of upgraded to the JASMA carbon/kevlar belt f00
ALLxMotor DA
Sep 6, 2008 06:10 AM
turbociv
12
May 1, 2004 06:43 AM
Richard.
16
Jan 19, 2004 10:20 PM
allmotorhatch
Jun 8, 2003 05:57 AM
