do i need an alignment after this?
Old Nov 18, 2005 | 09:25 AM
sleeperteg's Avatar
Default do i need an alignment after this?
I have a 96 Ls that i recently dumped on some Tien SS coilovers and i wanted to adjust the height in tha front... i dont have camber kits yet so i tried not to dump the car past 1.5" . Now i want to lower the front a little more but im hearing from some people that i will need an alignment after i take off my wheels and make my height adjustments... i was under the impression that the only thing that could get messed up was the toe... figure i dont have camber kits so there is only so much they can do to get it within spec... also i dont kno that i really trust the folks that told me this all that much and i for sure dont have a definite answer... so i aint fuggin with it until someone can provide a solid answer.
thanks in advance and sorry for the lack of knowledge here......
Old Nov 18, 2005 | 10:24 AM
EK k kay's Avatar
Default Re: do i need an alignment after this? (sleeperteg)
Everytime you adjust your ride height you should get an alignment so your toe can be set to 0. You can still drive without an alignment, but your tires may start wearing on the insides very quickly. Don't worry about the camber, it does wear out your tires, but not as quick as toe will.
Old Nov 21, 2005 | 09:14 AM
sleeperteg's Avatar
Default Re: do i need an alignment after this? (EK k kay)
right on brotha....
raphael
Mar 23, 2010 05:31 PM
austrian type-R
Jul 8, 2003 10:46 AM
IgniteTeg
Apr 17, 2002 07:53 PM
Phat Corolla
Jan 10, 2002 10:27 PM
Chip398193
Jul 29, 2001 11:38 AM
