Help!!!
Old Nov 18, 2005 | 04:10 AM
Ph0eNix's Avatar
Default Help!!!
I recently installed a jdm header. The car pops the check engine light. Now the speedometer is not working along with the cars headlights and interior lights dim in and out. I wanted to know if anyone has any idea what could cause all this. Is it because of the CE light? Thanks!
Old Nov 18, 2005 | 05:37 AM
JODYG35950's Avatar
Default Re: Help!!! (Ph0eNix)
What code is it giving you? Also, it sounds like you have some bad grounds with the lighting acting funny.
Old Nov 18, 2005 | 04:59 PM
Ph0eNix's Avatar
Default Re: Help!!! (JODYG35950)
I got the CE light checked and got 2 codes...P-0141 & P-1298
Old Nov 19, 2005 | 10:21 AM
mmuller's Avatar
Mad Scientist
P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit
Malfunction
P1298 Electric Load Detector (ELD) Circuit High Voltage
Mely
Nov 17, 2015 02:15 PM
Mely
Nov 15, 2015 09:41 AM
Ph0eNix
Nov 20, 2005 04:39 PM
SjCiViCHB
May 1, 2003 01:20 AM
vtecfiendsh
Feb 12, 2003 10:10 AM
