will a 94 integra rear suspension work for disk swap on 89 crx si??
Old Mar 11, 2002 | 08:01 PM
internet ay's Avatar
Default will a 94 integra rear suspension work for disk swap on 89 crx si??
i want to do a rear disk swap and i have access to a 94 integra rear suspension will this work?? i know the 90-93's work but what about the 94??
Old Mar 11, 2002 | 08:54 PM
EF'n Fast's Avatar
Default Re: will a 94 integra rear suspension work for disk swap on 89 crx si?? (internet ay)
i'm curious too.
Old Mar 12, 2002 | 05:57 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
3rd gen Integra suspension bolts right up to 2nd gen CRX chassis. I helped build up a rex once and we did just that.
Old Mar 12, 2002 | 06:15 AM
Mugen Dom's Avatar
Default Re: will a 94 integra rear suspension work for disk swap on 89 crx si?? (PatrickGSR94)
any rear control arm form any 2nd gen and up integra the rsx wont fit unless they kept it the same but they didnt cause they are asses, any civic except the 7th gen will work also for the same reasons. u can even use type r brakes and have 5 lug if its got abs just cut the line it still works
Old Mar 12, 2002 | 11:11 AM
Default Re: will a 94 integra rear suspension work for disk swap on 89 crx si?? (jdmB18hatch)
what lower control arm do i use the crx or the integra and also what upper arm do i use??
Old Mar 12, 2002 | 11:26 AM
CRX-RX's Avatar
CRX, the only part you use from the new stuff is the trailing arm and brakes.
Old Mar 14, 2002 | 11:30 AM
Default Re: will a 94 integra rear suspension work for disk swap on 89 crx si?? (CRX-RX)
will the 94 integra 2dr e-brake cables work with this swap????????
Old Mar 14, 2002 | 07:19 PM
Mugen Dom's Avatar
they should fit with a little slack extra on a rex its not hard to swap urs on
TNight
Jan 13, 2014 07:28 PM
RevinRex
Suspension & Brakes
Oct 19, 2005 04:41 PM
93 VTEC
Dec 10, 2004 08:50 AM
type Gendy
32
Jul 23, 2004 01:31 AM
B2FiNiTY
17
Mar 25, 2004 03:17 PM
