LS or GSR for turbocharging?????
Old Mar 11, 2002 | 07:45 PM
blazin's Avatar
Default LS or GSR for turbocharging?????
Which engine is best suited for turbocharging taking into consideration things like compression, tranny gearing,stock bottom end.Is the Vtech a better choice for it's VTECH and extra block lubing capabilities.I've also heard that the LS trannies gearing is better for turbo.I want to hear from some experienced FI people please.Thanks
Old Mar 11, 2002 | 07:54 PM
reVVin's Avatar
Default Re: LS or GSR for turbocharging????? (blazin)
I'm not experienced but I've ALWAYS heard that LS is better for turbo mainly because the fact of lower compression ratio.
Old Mar 11, 2002 | 08:48 PM
Erik_Pb_Foot's Avatar
New User
Default Re: LS or GSR for turbocharging????? (krrrrrrzyrebel)
GSR
To do it right you are going to have to pull the engine apart and do some internal work anyway... replacing the pistons in the GSR would eliminate the LS's only advatange (aside from the slightly marger displacement).
Better yet... b16a2 or 3. better rod/stroke ratio
SYDNEYSIDER's Avatar
VTECH....hahahahahahahahaahahahahahahahhaahaha ok I'm done now.
Anyway, LS, GSR......It's a freakin long *** debate. And please do not respond just cause you heard from some guy who said so. Also do not respond if you cant back your **** up. Use the search function. They have detailed explanations that I wouldn't want to type. Can we please move this to the newbie questions.....
Old Mar 11, 2002 | 10:28 PM
bacid's Avatar
Default Re: LS or GSR for turbocharging????? (GS-R_ocks)
if you can afford the extra price for a GSR, might as well get that and turbo it!
It's always better to start modding a better car.. rather than modding a inferior one.
That and if you really up the boost u will have to tear apart the engine anyways!
Old Mar 11, 2002 | 10:35 PM
Homer_Simpson's Avatar
Default Re: LS or GSR for turbocharging????? (bacid)
VTECH?? isnt that a phone???
Will-
Old Mar 11, 2002 | 11:10 PM
BlackB18C's Avatar
Default Re: LS or GSR for turbocharging????? (*****rAcEr)
LS isn't better for lower compression, it's better for longer stroke. In Either motor you're probably going to install low compression forged pistons for FI. In turbo applications it's common to lose power at the vtec crossover. So for those reasons I'd have to say an LS would be a better bet for turbo
N2X0
Oct 13, 2002 05:01 PM
1hotintegra
May 22, 2002 03:28 PM
1hotintegra
May 20, 2002 04:54 PM
blazin
Mar 11, 2002 09:28 PM
xsnrgsr
Aug 13, 2001 01:42 PM
