fuggin smoke screenin everyone. Could it be valve seals?
Old Mar 11, 2002 | 07:38 PM
synergy004's Avatar
Default fuggin smoke screenin everyone. Could it be valve seals?
Anyone have any probs with smoking, is so what were the symptoms and what did you do to cure it.
I have a B18A1 fully built with a custom turbo set up. I replaced everything from top to bottom but seem to now be getting some smoke (ALOT) ONly when I am warming the car it does it. When it reaches 180 degrees it stops but still get a lil everytime I stay steady in one gear. Smoke is whitish gray. Did compression tests, took the head off, checked rings, oil stays good, no coolant probs. All have been in good order. Replaced with new gaskets. Any other suggestions?
THANKS for your advice in Advance
Teggymaniac379
Aug 24, 2017 05:47 AM
oranginal
Jul 3, 2009 11:37 AM
xcellorator
Jun 8, 2006 02:41 PM
M@
Aug 23, 2005 09:24 AM
