Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Where to spend money next?
Old Nov 17, 2005 | 06:46 PM
pmachan's Avatar
Default Where to spend money next?
So I am at a crossroads with my 99 SiR.
I am up in the air with what to change next to improve laptimes.
Car currently is a street car used in Solo I, and will see some limited Solo II.
Setup:
Neuspeed sports
KYB AGX
22mm A-spec rear bar/brace
The car works pretty well with this setup and is a really nice daily driver. However, I would like a bit more from it, the guys I run with in Solo I are getting away from me a bit.
So...
My choices at the moment are:
New suspension, thinking K-sports or some other full coilover with 400-500 pound springs, in that range anyway, Maybe new Omni adjustable. Even sweeter would be a used GC/Koni setup..
Or an LSD
I am not sure which will give more bang for the buck on the track, and thats an important thing for me.
Old Nov 17, 2005 | 08:08 PM
.RJ's Avatar
.RJ
Default Re: Where to spend money next? (pmachan)
Tires.
Old Nov 17, 2005 | 08:12 PM
94accordsedan's Avatar
Banned
Default Re: Where to spend money next? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Tires.</TD></TR></TABLE>
What he said.
Old Nov 18, 2005 | 04:05 AM
davidnyc's Avatar
What are the rules for your solo 1 class?
Old Nov 18, 2005 | 07:57 AM
pmachan's Avatar
Common now, you don't think I already have tires and know the importance of them?
I am on Hoosiers.
Old Nov 18, 2005 | 08:54 AM
chjkingme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pmachan &raquo;</TD></TR><TR><TD CLASS="quote"> Maybe new Omni adjustable. Even sweeter would be a used GC/Koni setup..
Dat der Konizzle thingies be cheaper den dum Omnis, I reckon.
{patiently awaiting Omniman's dyno graphs...he sent em to RJ, right?}
Your class rules would be helpful, as well as the rest of the car info.
Old Nov 18, 2005 | 08:57 AM
Civic44's Avatar
Default Re: Where to spend money next? (chjkingme)
I think I'd get some higher rate springs (maybe H&R Race or GC) and keep those shocks if they are still in good shape, then add a used OEM ITR LSD (wow, lots of acronyms), which will bolt right into your tranny and costs only about 400$.
Old Nov 18, 2005 | 02:11 PM
Jimmy L's Avatar
Default Re: Where to spend money next? (Civic44)
He'll need an ITR or GSR final drive to put the ITR LSD in his 99 si. It might be better to send your diff to OPM if you don't want to change the FD. I think a good question is where do you think the car needs improvement? In the corners or on the straights?
Old Nov 18, 2005 | 03:33 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chjkingme &raquo;</TD></TR><TR><TD CLASS="quote">
I didnt get any dyno shizzle I just offered to pay for shipping to have it done
Konis = the shizzle dizzle, for my budget.
Old Nov 18, 2005 | 03:38 PM
TeamSlowdotOrg's Avatar
Honestly, I say grab a set of coilovers and see if you think the shocks totally suck with the 500 lb springs. I bet you'd be pleasantly surprised with how much better it works and save yourself some money in the short run at least. Then you can buy Konis later when you're ready. I'd adress the mushtasticness first and then worry about damping it as best as possible. Advice counter to what I would normally give, but you know how to turn a wheel so I'm less inclined to think you'd put it in the wall with stiffer springs and less than perfect dampers.
riceforlife
Suspension & Brakes
10
Dec 21, 2007 10:47 PM
CivicMike
33
Jul 23, 2006 11:14 PM
SJR
12
May 5, 2005 04:28 AM
racekar
31
Apr 30, 2004 02:08 AM
lowboost civ
Jul 28, 2003 07:00 PM
