drag h22 turbo no speedometer need help
Old Nov 17, 2005 | 05:30 PM
fastforwardracer's Avatar
Default drag h22 turbo no speedometer need help
here is the deal. 98 civic coupe h22 motor turbo running mark william spool & axles. tec 3 is the brain. when we started this project stripped out ecu & all wireing harness. spool has no gear to turn speed sensor. is there any way to get a speedometer for the gear based boost controler? can u help a novice race team? thanks for any help.
Old Nov 18, 2005 | 08:47 AM
Rtype16's Avatar
Default Re: drag h22 turbo no speedometer need help (fastforwardracer)
What ECU are you using now?
Old Nov 18, 2005 | 09:08 AM
Default Re: drag h22 turbo no speedometer need help (Rtype16)
tec 3. i think the problem is there is no gear on the spool 2 drive the speed sensor. even then i don't know if there was one could i wire the speedometer to the speed sensor direct or does it need to be thru the ecu like factory.
crxses
Jan 10, 2011 01:49 AM
kasper
Oct 3, 2003 09:06 AM
