intermittent wipers not working - checked and searched - what am i missing
Old Nov 17, 2005 | 05:02 PM
hb_guy's Avatar
Default intermittent wipers not working - checked and searched - what am i missing
97 civic
intermittent wipers stopped working, so i took the switch out and cleaned the terminals which weren't dirty. i know there is no relay for this function, so what am i missing? switch bad or something i am overlooking. any help appreciated. really annoying with the rain now.
Old Nov 18, 2005 | 03:19 AM
BigRonDawg's Avatar
Default Re: intermittent wipers not working - checked and searched - what am i missing (hb_guy)
does the other 2 settings work? if so does the wipers go back to their resting place?
Old Nov 18, 2005 | 03:47 PM
hb_guy's Avatar
Default Re: intermittent wipers not working - checked and searched - what am i missing (BigRonDawg)
yes, everything else works fine, just the intermittent setting stopped working
Old Nov 18, 2005 | 05:15 PM
Freemantle's Avatar
Is your ABS working?
Old Nov 18, 2005 | 05:45 PM
VTAKKK!!'s Avatar
get a wiring diagram and trace the circuit
and im pretty sure there is a relay. how do you think the intermitten feature works
Old Nov 18, 2005 | 06:06 PM
hb_guy's Avatar
Default Re: intermittent wipers not working - checked and searched - what am i missing (Freemantle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freemantle &raquo;</TD></TR><TR><TD CLASS="quote">Is your ABS working?</TD></TR></TABLE>
don't have abs om a 97 civic dx and there is a relay but not one alone for the intermittent wipers. everything works but the intermittent part
Old Nov 18, 2005 | 06:13 PM
tominos's Avatar
do you happen to have a helms manual? look at page 23-215
it shows a circuit diagram with an integrated control unit (has built in intermittent wiper relay circuit)
to see if your wiper switch has crapped out, check for continuity for the intermittent swithc position, between terminals 1 and 7, and 3 and 4. i can't really explain it well.
Old Nov 18, 2005 | 07:24 PM
VTAKKK!!'s Avatar
helms to the rescue.................. again!!!!
Old Nov 18, 2005 | 07:47 PM
hb_guy's Avatar
Default Re: intermittent wipers not working - checked and searched - what am i missing (tominos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos &raquo;</TD></TR><TR><TD CLASS="quote">do you happen to have a helms manual? look at page 23-215
to see if your wiper switch has crapped out, check for continuity for the intermittent swithc position, between terminals 1 and 7, and 3 and 4. i can't really explain it well. </TD></TR></TABLE>
no i got it, thanks for the info, no helms, but i have a haynes - didnt help much
Old Jan 2, 2006 | 02:11 PM
.y2a.'s Avatar
could this be a fuse issue? I'm having the same problem all of a sudden this morning as well. I've also lost my dome lights and my intrument panel wont turn off the door ajar and trunk ajar light, trunk light, Be-be-be-beep sound you car makes when the keys in the ignition is gone too... I'm thinking they all have to be related....
Modified by .y2a. at 6:24 PM 1/2/2006
edit... got it figured out by swapping the 7.5A fuse under the dash....
Modified by .y2a. at 8:08 PM 1/2/2006
01_ITR
Aug 3, 2015 03:38 AM
NorthernXposure
Sep 20, 2007 12:02 PM
M2B4
Oct 18, 2006 07:46 PM
axtran
Jan 25, 2006 10:23 AM
