timing
Old Nov 17, 2005 | 03:38 PM
doggworld1233's Avatar
Default timing
what would happen if the timing in my 95 is off? would it jumo around and then start to pull hard in the upper rpms like 4000+?
justin
Old Nov 17, 2005 | 03:39 PM
littleredcivic's Avatar
Default Re: timing (doggworld1233)
it is possible, but it seems like you have a problem elsewhere. check timing by using a timing light. it sounds like you may have a spark plug problem or another ignition problem that may be misfiring at low rpm.
Old Nov 17, 2005 | 06:29 PM
swindler86's Avatar
your timing might be slightly retarded
Pancho2193
Mar 13, 2013 10:38 AM
GoodSpeed150
Mar 2, 2011 06:34 AM
Ran4it2
Jun 4, 2009 07:39 AM
rhdins
Aug 25, 2008 07:26 PM
jakscivic
11
May 1, 2006 08:36 PM
