engine vibration help
Old Nov 17, 2005 | 02:15 PM
bogil05's Avatar
Default engine vibration help
Hello everyone! I am new to this site and I hope you guys can really help me on my Civic Lx 1992. Its been in the garage now for almost 6 months, and i was able to start it just last week with help of this site just reading all of the problems and answers.
Anyway, the car already have more than hundred thousand miles. Since i made it to start, the the problem now is the engine itself shakes or vibrate so bad even when the rpm gauges tells me that it still in range, but sometimes when I press on the accellerator and let it go, rpm goes all the way down and engine dies. I really dont have a problem of starting the car now, its just the vibration...Can somebody help on this??
Old Nov 17, 2005 | 02:23 PM
EJ7's Avatar
EJ7
Default Re: engine vibration help (bogil05)
Change your oil?, it's a start, 6 months is a long time.
Old Nov 17, 2005 | 07:47 PM
bogil05's Avatar
Default Re: engine vibration help (EJ7)
already did. Thanks! Anything else?
Old Nov 17, 2005 | 07:55 PM
Chilly61383's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bogil05 &raquo;</TD></TR><TR><TD CLASS="quote">Hello everyone! I am new to this site and I hope you guys can really help me on my Civic Lx 1992. Its been in the garage now for almost 6 months, and i was able to start it just last week with help of this site just reading all of the problems and answers.
Anyway, the car already have more than hundred thousand miles. Since i made it to start, the the problem now is the engine itself shakes or vibrate so bad even when the rpm gauges tells me that it still in range, but sometimes when I press on the accellerator and let it go, rpm goes all the way down and engine dies. I really dont have a problem of starting the car now, its just the vibration...Can somebody help on this??</TD></TR></TABLE>
Check the timing, your ignition ie plugs, wires, distributor. Check compression, one of the cylinders could not be firing. I had that problem before, that sucks.
Old Nov 22, 2005 | 07:54 PM
bogil05's Avatar
Default Re: engine vibration help (Chilly61383)
Let say the problem is compression, can you give me rough estimate how much it is going to cost me on repair. Cause i want to keep this vehicle... Thanks!
Old Nov 22, 2005 | 08:17 PM
lohatch's Avatar
depends what the problem is and where you take it to. odds are that it is misfiring on a cylinder or the firing order is not correct.
check you plug wires and make sure they are correct
Old Nov 22, 2005 | 08:25 PM
old man neri's Avatar
Gasoline does have a shelf life. That's why they self gas stablizer for storage. Water could have build up in there too.
Could be a combination of minor problems that add up to something bad.
DJLikwid
Honda Civic (2006 - 2015)
May 30, 2011 09:31 AM
hondatuner208
49
Mar 28, 2008 12:58 PM
leviathan4444
16
Jul 11, 2006 10:17 PM
98teg
Jan 3, 2005 07:36 AM
