E.C.U
Old Nov 17, 2005 | 02:04 PM
1990AccordEX's Avatar
Default E.C.U
Does anyone know where the E.C.U. is located on a 2003 Accord Sedan Ex V6 auto
and to when does VTEC kick in
Thanks
Old Nov 17, 2005 | 02:19 PM
BLKFLSH's Avatar
Default Re: E.C.U (1990AccordEX)
The ECU is under the dash, right in the center, behind the center console. I think v-tech is variable depending on acceleration and rpms etc.
Old Nov 17, 2005 | 02:24 PM
Default Re: E.C.U (BLKFLSH)
if i behind the center console how can i see if it giving a code
Old Nov 17, 2005 | 02:30 PM
StyLz's Avatar
Your check engine light flashes codes dude. Not the ECU itself.
Old Nov 17, 2005 | 02:45 PM
BLKFLSH's Avatar
If the light is on first off check the gas cap. the little plastic cable that holds the cap gets caught under the cap, it doesn't seal, and you get the check engine light. If that's what is was, the light will turn itself off after a couple of trips. (start ups) check that out first, then let us know if it is something else.
Mesm23
Jun 13, 2017 09:11 AM
91accordman
Aug 7, 2008 05:05 PM
1320king
Jul 22, 2007 12:32 PM
shahmiezan
Jan 19, 2007 05:39 AM
Project_EK
Aug 13, 2005 04:08 PM
