92 Engine into 91 EX
Old Nov 17, 2005 | 12:38 PM
.dave's Avatar
i HAS questions ?
Default 92 Engine into 91 EX
The transmission on my 1991 EX died a couple years back and I finally have time to get around to fixing the car. I managed to pick up a 92 engine and transmission for really cheap so I'm thinking of dropping in the engine and transmission. The 91 is OBD0 and the 92 is OBD1 if I remember correctly, so in order to still use the 91 wiring harness and such I was thinking of swapping the head from the 91 engine onto the 92 block. Are there any sensors that the 91 block has that the 92 would not? Also, as far as the transmissions go, are they the same or will it take a little bit of work to use the newer transmission?
Old Nov 17, 2005 | 12:58 PM
.dave's Avatar
i HAS questions ?
Default Re: 92 Engine into 91 EX (daveG)
Is it possible to use the 91 distributor on the 92 head with the 91 intake manifold etc?
Old Nov 17, 2005 | 03:24 PM
213374U's Avatar
0x5359-0055
Community Builder
Why go to all that trouble??? Just bolt up the tranny from the 92 and call it a day.
Old Nov 17, 2005 | 03:53 PM
.dave's Avatar
i HAS questions ?
Default Re: 92 Engine into 91 EX (Vt4cPwn35)
Does the 92 tranny have all the same sensors/connections/etc as the 91? I'm referring to an automatic transmission by the way.
Old Nov 17, 2005 | 04:27 PM
patastinky's Avatar
yes. if you want I can do this swap for you.
Everything bolts you just won't be using your "S" button anymore since the 92+ don't have it
patastinky's Avatar
Default Re: 92 Engine into 91 EX (patastinky)
btw your wrong. 90-93 accords are all OBD1
Old Nov 17, 2005 | 04:28 PM
patastinky's Avatar
Just swap the transmissions over and sell the 92 motor.
Old Nov 17, 2005 | 05:30 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patastinky &raquo;</TD></TR><TR><TD CLASS="quote">yes. if you want I can do this swap for you.
Everything bolts you just won't be using your "S" button anymore since the 92+ don't have it</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patastinky &raquo;</TD></TR><TR><TD CLASS="quote">btw your wrong. 90-93 accords are all OBD1</TD></TR></TABLE>
Sweet, thanks. Thanks for the offer, but I can handle the swap. This is nowhere near the level of work that I've done on my Civic.
Old Nov 17, 2005 | 07:29 PM
.dave's Avatar
i HAS questions ?
The engine in the car right now is one that I picked up from a junkyard a few years back for $200, so I'm probably going to just drop in the whole new transmission and engine as one unit. Patastinky, according to what you said everything should bolt up fine, correct?
Lyrically sick
Jun 4, 2015 10:48 PM
gdrew888
Mar 4, 2013 10:40 PM
dunkd
Northeast (Sales)
Dec 28, 2005 09:05 PM
Original TEGFREAK
Dec 26, 2004 07:50 AM
