When changing brake pads, what part of the caliper should be lubed?
I've heard to lube the "caliper slide pins," but what are those?
If i were at home i'd have a set of calipers to look at, but i'm about 50miles away and unable to check it out.
I believe its the two bolts in the rear of the caliper, top and bottom. I'm not completly sure about honda's. But I helped a friend with a DSM, and we relubed those to bolts with anti-sieze.
Ali
Ali
Clean and use silicon high temp lube on the two bolts/slider pins and you can use it on the ends/backs of the pads that contact the caliper as well. Make sure to keep the rotors and friction surface of the pads clean.
Nocturnal
Jul 11, 2007 09:29 PM
