b18b.. fitv
im talkin about the valve thing under the t/b with the coolant hoses running to it.. is a 98 b18b supposed to have one? mine doesnt.. the hoses go right to the t/b im thinking maybe somone switched out the t/b.. im asking because im having idle problems and cold start problems..(dies when cold unless i give it gas till it warms) engine is stock and in a 98 civic dx.. with stock ecu ( thinking might be a problem as well)
I believe they stopped using the Fast Idle Valve on OBD2 engines, which leaves the cold idle operation up to the ECU. I don't know if the ECU is your problem or not. Sorry... not much help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kchungb17a »</TD></TR><TR><TD CLASS="quote">I believe they stopped using the Fast Idle Valve on OBD2 engines, which leaves the cold idle operation up to the ECU. I don't know if the ECU is your problem or not. Sorry... not much help.</TD></TR></TABLE>
You are correct. Only OBD1 engines are equipped with the FITV. The cold idle is controlled only by the IACV on OBD2+ cars.
ah... guys.. i think i foud somthing else, its a 98 civic with b18b running of the stock civic dx ecu.. if the stock sohc dx engine had a fitv, wouldnt that mess with the idle seeing how the b18b doesnt have it?
racer_X_123
Oct 25, 2005 01:43 PM
