Cluster Problem
Old Nov 17, 2005 | 11:14 AM
actionfigure's Avatar
Default Cluster Problem
Made you look!!! No, for real this time. I have a problem with my gauge. The gas level keeps going up and down and NO! Im not taking about when I add gas that it reads full.
For example, I have a half a tank. Let it later reads that I have 3/4 and then later its says I have 1/4. Its strange. Is it the wiring? I dont have the money to replace it right now but if you know of a site thats cheap or under $35 that would be great.
Other wise how can I fix this?
NOTE: Im a noob! so be basic.
Old Nov 17, 2005 | 11:15 AM
92ehatch's Avatar
Default Re: Cluster Problem (actionfigure)
its normal, as u take turns it will change the level because of the way it reads the gas.
if you take a right hand turn it will go down, left hand it will go up.
Old Nov 17, 2005 | 12:04 PM
postman's Avatar
not normal, the rheostat in your fuel sending unit is probably going bad inside your gas tank
xxvinxx43
10
Aug 10, 2011 08:54 PM
tekniq
Jan 18, 2009 01:17 AM
Bayareajdm
Apr 30, 2007 02:02 PM
soopafly828
Mar 25, 2003 03:13 PM
accordfreak
Jan 24, 2002 12:44 PM
