EK suspension into EG
Yes I've searched and couldnt find an answer. My question is, will a shock/spring from an EK Coupe combo fit into an EG hatch? Any help wquld be greatly appreciated.
Thanks
Thanks
It will fit OK, but you will need to narrow the center bushing of each rear LCA. The opening in the "fork" of the rear struts are 40mm on the EK instead of 50mm on the EG. Fronts are straight bolt-on.
-AT
-AT
Momentum
May 6, 2009 10:43 AM
