how to fix the header bolt threadings from the head? =/
i recently took off my header to change the gasket, and once i put it back on. 2 of the bolts went in, but wouldn't tighten, so i pulled it back out and noticed that it actually stripped out the threading from the cylinder head. so now, the bolt just goes in and out. is there a way to fix it???
it's #6 in the image
You are more than likely going to have to re-thread the head with a slightly larger size, and then you can use a bolt with the same thread pitch to bolt into the head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">I would try using a Heli-Coil inserts to repair it. </TD></TR></TABLE>
that's what I used. be sure to torque to spec when you reinstall the header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Try this:
http://www.mcmaster.com
The metric choices may be limited.</TD></TR></TABLE>
damn, thats an awesome site, thanks dude.
