Cleaning my engine (pics inside)
Old Mar 11, 2002 | 05:47 PM
KooK's Avatar
Mustang Sally
Default Cleaning my engine (pics inside)
How do I get my engine as clean as it was when I first bought it? The winter has done hell to it and when I first bought it, it looked like new!! I want to go back to the dealer but I just got in a HUGE fight with them because they welded my cat heatshield instead of replacing it. So can I get some help here please? Heres my car when I first got it... Check out how clean the engine was!!
Thanks guys! http://www.vwbaja.8m.com/test1.html
Old Mar 11, 2002 | 05:54 PM
mantic6t9's Avatar
Default Re: Cleaning my engine (******)
here is mine and it's 9 yrs old
Old Mar 11, 2002 | 05:59 PM
Reid's Avatar
Global Moderator
Default Re: Cleaning my engine (mantic6t9)
What's your method of cleaning?
Old Mar 11, 2002 | 06:04 PM
mantic6t9's Avatar
Default Re: Cleaning my engine (Reid)
simple green, tooth brush, synthetic steel wool, small wire brush, mothers aluminum polish.
KooK's Avatar
Mustang Sally
Took the words right out of my mouth!
Anyway, thats when I FIRST bought the car! A few months later the engine is dirty and needs cleaned. Thats what I was asking... How do you clean it so well?
Old Mar 11, 2002 | 06:06 PM
KooK's Avatar
Mustang Sally
Crrrraap! I was hoping that someone told me there was a spray I could just put on there and was it off Alright alright... I guess I'll take a whole day out to clean it when it gets warm again. Thanks!
Old Mar 11, 2002 | 07:48 PM
.nate's Avatar
Believe it or not carb cleaner or brake cleaner sprays on and dissolves the oil and grease
carb cleaner has a shitload of uses... and most of us dont even have carbs! LOL
Old Mar 11, 2002 | 08:35 PM
fiebru1119's Avatar
Default Re: Cleaning my engine (TheFLY)
i was thinkin of doing this, besides the obvious (distributor, wires, electrical...) what do i need to cover before i hose my engine bay down? thanks
Old Mar 11, 2002 | 08:46 PM
Frosty_spl's Avatar
Default Re: Cleaning my engine (fiebru1119)
make sure you dont get water in the sparkplug holes.
i did this one time, i thought i fried the distributor. i ran it for a week on 2 or 3 cylinders. then i took the boots off and there was water down in there. my sparkplug cover was on and everything, thats why i didnt think it was possible.
Old Mar 12, 2002 | 10:43 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My engine was pretty dirty when I got it (one of the valve cover nuts was snapped, oil was leaking out ). My friend went w/ me to the coin-op carwash and he cleaned my engine off for me. He sprayed a bit of degrease on there and went to town w/ the pressure washer. We didn't cover anything, he was just careful to not spray DIRECTLY onto the distributor. I've never had any problems. Here it is after cleaning.
Old Mar 12, 2002 | 10:45 AM
Thayne's Avatar
New User
Very clean!
-Thayne
Old Mar 12, 2002 | 11:21 AM
mantic6t9's Avatar
Default Re: Cleaning my engine (E30 325es)
Thanks Here is was it lookied like after i painted and swaped valvecovers.
It went from this
to this
to this
to this
Painting your valve cover and heat sheild make a huge difference.
Old Mar 12, 2002 | 11:43 AM
Community Builder
Yeah I need to paint my heat shield, too.
Old Mar 12, 2002 | 02:26 PM
KooK's Avatar
Mustang Sally
My bugs have carbs so yea I have the carb cleaner... BUT THAT STUFF IS STRONG! Are you guys sure I can spary it on my engine? I'm kinda worried about the paint around it!
Old Mar 12, 2002 | 02:30 PM
GTEater's Avatar
blast it at the carwash with hot water and then you can spray Tire shine foaming spray.....my friend does it and it works really well.......makes all the hoses look like they've been armor-all'd
Old Mar 12, 2002 | 05:51 PM
VTi NA's Avatar
Default Re: Cleaning my engine (GTEater)
Patrick, did you guys cover the distributor and the battery when you sprayed it down with the high pressure stream? What degreaser did you guys use?
Old Mar 12, 2002 | 06:01 PM
mantic6t9's Avatar
Default Re: Cleaning my engine (STi -RA)
Yes you need to cover your distributor and air filter it it's exposed, i also cover my alternator. Use simple green for your degreaser. It's non toxic and will not discolor hoses and parts. Only use the high pressure on the engine tranny and block if needed. I've never used high pressure just a good ol water hose works for me.
Old Mar 12, 2002 | 08:44 PM
rudeS2k's Avatar
Default Re: Cleaning my engine (PatrickGSR94)
what kind of paint did you use for the heatshield??
Old Mar 12, 2002 | 09:12 PM
mantic6t9's Avatar
Default Re: Cleaning my engine (98ITR0884)
Dupli-Color 500 degree ceramic engine enamel in low gloss black. It was only like that for a month so i don't know if the 500 degree paint will hold up over time. I'm sure that thing gets hotter then 500 degrees. You may want to use 1200 degree paint. The 500 degree is good on the valve cover i used the same paint for both. Here is a how to i wrote a while back. The only thing i need to add is that you need to put a few coats of clear coat on your finnal color. http://www.geocities.com/mysihb/HowTo.html
Old Mar 14, 2002 | 09:34 AM
dplatt's Avatar
Here's my brother's 93 Civic Engine Bay. And just to add how proud I am of my bro's car, it ran a 14.9 quarter @ 93mph on street tires (16" Yok A520s). All motor D16Z6.
To see the full size image of this picture, copy and paste this link to your browser...
http://www.imagestation.com/picture/...a.jpg.orig.jpg
I detailed it for him using the methods found on this link.....
http://www.g2ic.com/tegtips/engine/#cleanengine
Old Mar 14, 2002 | 12:25 PM
Mr. Thunderlips's Avatar
yeah, that 500 degree paint wont hold up on the heat shield...it will eventually crack off...but it does take soem time...and re-painting your valve cover did wonders for your car. one thing no one has mentioned, but is important, after washing out your engine bay, its a good idea to start your car up, close the hood, and let it run for a few minutes to get some of the water dried up from certain areas...
Old Mar 14, 2002 | 02:47 PM
mantic6t9's Avatar
Default Re: Cleaning my engine (Slo_Teg)
Yeah i take mine for a short spin after i'm done washing it.
Old Mar 14, 2002 | 07:08 PM
ysrhatch's Avatar
New User
there should be shops that allow u guys to STEAM CLEAN. which will look just like that for only 40-50 bucks.
truevietluv636
17
May 17, 2007 03:03 PM
Integra Integra
Apr 26, 2006 08:02 AM
integra714
Feb 2, 2005 07:25 PM
JDMlyfestyle
Nov 29, 2003 01:43 PM
LilDevil
23
Apr 18, 2002 09:29 AM
