urethaneFOR motor mounts...will this work it work?
Guest
Posts: n/a
if i use urethane (the black stuff in a tube you can get at homedepot) as an adheasive to hold together my energy suspension inserts and torsion mounts, will it stick FOREVER without having to use those zip ties? THANKS IN ADVANCE
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peacexisxfree »</TD></TR><TR><TD CLASS="quote">yes. just make sure you let it cure. dont slap the poly on then stick it on your car.</TD></TR></TABLE>
have you done it before? that stuff doesn't look like it will hold up.
ive done this also. It works, but mine didnt seem to last that long. Started feeling softer and weaker over time.
crxaddikt
Jun 8, 2011 08:15 AM
turboex
Jan 26, 2005 07:51 AM
