Ceramic coated exhaust ports
Old Nov 16, 2005 | 08:44 PM
OrangeBoost's Avatar
Default Ceramic coated exhaust ports
Im just curious if anyone here has ever tried ceramic coated exhaust ports? I wonder if the gain with turbo in particular would be worth it.
Old Nov 17, 2005 | 05:54 AM
bump Im sure someone must have at least done some reading on this?
Old Nov 17, 2005 | 10:27 AM
GZERO's Avatar
Default Re: (OrangeBoost)
free bump
From what i read, it's good cuz they take some heat away from the head and into the exhaust, also, since the coating leaves the surface smooth it helps reducing turbulence on the exhaust side.
I think the most important part is to isolate the head from the extreme heat of the exhaust, meaning your oil will thank you and it will be easier on your cooling system, off course, not a big amount.
I have seen pics of headwork in which the hole chamber and the exhaust ports are ceramic coating, but i can't remember if they did the coatings on the intake sides.
Old Nov 19, 2005 | 08:04 AM
bump
Old Oct 13, 2007 | 09:34 AM
hovic's Avatar
sorry for bring this thread back
I´m very interested in some more infos about ceramic coating the exhaust ports and the chambers too. I´ve found some pics:
and here´s the link to the original write up :-)
http://www.dprracing.com/SearchResults.asp?Cat=17
Old Oct 14, 2007 | 03:07 AM
hovic's Avatar
Default Re: (hovic)
bump for some infos and experiences
FXAutodesign
Performance
Jan 13, 2012 11:40 AM
00situner
Dec 10, 2005 09:59 AM
slowestcivicever
Jul 29, 2003 10:39 AM
