any modification to intstall obx lsd??
Old Nov 16, 2005 | 06:21 PM
eg:R's Avatar
Default any modification to intstall obx lsd??
any modification to intstall obx lsd?? is it a stright drop in? shims?? planning to get one for my 95 b16 tranny.
Old Nov 17, 2005 | 06:28 AM
b18bturbo's Avatar
Default Re: any modification to intstall obx lsd?? (eg:R)
you will need a specific shim to install i sell these as well but the issue we came across is that hte honda shims are just too big and even using the smallest shim is still to big to make ti work properly. so you have to actually shim it using the smallest and grind some down to make it work properly. this is for b16a and ls diffs lsd9000 is the model on it
Old Nov 17, 2005 | 10:29 AM
unsungsohc's Avatar
Default Re: any modification to intstall obx lsd?? (b18bturbo)
^^^ what he said. i had to plane down my stock shim in my d16y8 to get it to fix correctly. No problems yet
Old Nov 17, 2005 | 05:32 PM
eg:R's Avatar
what sizes if the proper shims
Old Nov 20, 2005 | 05:23 PM
eg:R's Avatar
lsd dont' have shims do they, or is it for the input shaft??
da6xsi06
Transmission & Drivetrain
Oct 6, 2010 04:47 AM
essex
Jul 9, 2008 08:37 PM
93b16CivicSi
Aug 13, 2005 12:12 AM
turbotime
16
Oct 3, 2004 09:14 PM
citrusdrop
Oct 23, 2003 10:59 AM
