2000 Honda Accord SE Fuel Tank Sensor
Old Nov 16, 2005 | 06:08 PM
kdorn's Avatar
Default 2000 Honda Accord SE Fuel Tank Sensor
I have a trouble code P1456 which states that the fuel tank temp. sensor circuit malfunction. what do I look for to correct this condition and reset the dash light.
Old Nov 17, 2005 | 06:55 AM
JimBlake's Avatar
Default Re: 2000 Honda Accord SE Fuel Tank Sensor (kdorn)
Check your code list again...
P1456 should be an EVAP leak - fuel tank system.
Basically, your fuel tank isn't airtight like it's supposed to be. This is the code for a loose or leaking gas cap, but there's a handful of other things that can cause it.
After you rule out a bad gas cap, you can look for loose or disconnected vent hoses around the gas filler pipe. Maybe a leaky gasket where the fuel pump or gauge sender are mounted in the tank. Eventually you can worry about the pressure sensor on top of the fuel tank.
runtohell121
Dec 29, 2009 08:25 PM
Ferio4ya
Nov 30, 2009 01:17 PM
4doorH22
Apr 21, 2003 11:29 AM
