quick exhaust question
Doubt it, but that's an ESTIMATE....
https://honda-tech.com/zerothread?id=1365602
I wrote the thread about putting a JDM catback onto a USDM EP3, and the header & cat were taken from a Type-S because of their longer length.
IF the base RSX has a header & cat assembly that's the same length as the EP3's stock parts, then they'll be too short to fit a Type-S catback.
Also, the part numbers for catback systems are different for base and -S versions.
A Type-S exhaust can fit, and can be a simple bolt-on procedure if you change the header & cat as well... that's what I would say at the moment WITHOUT checking out the parts in person.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joshiscool »</TD></TR><TR><TD CLASS="quote">what is the adapter,and where do you get it?</TD></TR></TABLE>
search it boy
search it boy
Wataaah
Feb 19, 2006 07:10 PM
