cel 22 vtec works tho whuts up?
Old Nov 16, 2005 | 03:41 PM
rugbyplaya85's Avatar
Default cel 22 vtec works tho whuts up?
i did search found nothing that applies to me since vtec still works. i havea 94ls 97gsr powered obd1 car thats throwin a 22 we wired the 3 wires up for vtec and it kicks and kicks hard but still throwing this code, any ideas?
Old Nov 16, 2005 | 11:39 PM
Default Re: cel 22 vtec works tho whuts up? (rugbyplaya85)
jus did at least an hours wortha searchin over 24 pages of it, no luck noone seems to have this code and still be able to use their vtec why can i?.....more details if they help:
vtec screen is clean as a whistle all conections look fine i cant tell when the 22 code is tripping because im workin on a code 41 and 15 also but i did reset ecu and check codes and still got 22 multiple times. ive gone ona few joyrides in the car and vtec hits great and sounds great all the way to redline. no odd sounds from my engine bay other than my abs making a semi loud ticking noise that sounds like the pumps going to hell and maybe a bad bearing on my steering pump. (any help on these would be cool too). oil is great i just changed it. ecu is p72 incase i forgot to mention
Old Nov 17, 2005 | 02:24 PM
do you guys honestly all have no idea or whut from whut ive learned the p72 is the ground so a spliced ground is not needed but i just bolted down the ecu and still no luck. im trying everything i can think of and everything you guys seem to think could be it but anyone know more???
Old Nov 17, 2005 | 06:01 PM
4dr_all_day's Avatar
get another computer and see if it still does the same thing.. if it does then i dont know man... good luck with your problem
Old Nov 18, 2005 | 10:29 AM
Default Re: cel 22 vtec works tho whuts up? (4dr_all_day)
my buddys gotta p72 so ill give it a try
tavo.760
Dec 17, 2013 10:22 AM
TURBO DC2
Jul 17, 2005 06:30 AM
AllMotorB
Jul 1, 2005 08:22 PM
ninety9ex
Jan 26, 2004 07:40 PM
Hondasaurs
Apr 25, 2003 07:30 PM
