highest compression w/stock b18c5 block
Old Mar 11, 2002 | 04:38 PM
nighthunt6's Avatar
New User
Default highest compression w/stock b18c5 block
What's the most compression you can get out of a type R without touching the block (milling head, valves, head gasket etc....)
Old Mar 11, 2002 | 04:53 PM
Pinhead's Avatar
New User
Default Re: highest compression w/stock b18c5 block (nighthunt6)
oh yea forgot to mention (nighthunt6) was me on my roommates computer....I was just wondering this...also I'd be using Toda B or Jun3 cams
Old Mar 11, 2002 | 04:56 PM
Reid's Avatar
Global Moderator
Default Re: highest compression w/stock b18c5 block (Pinhead)
Without touching anything, you'll still be at 10.6:1.
Old Mar 11, 2002 | 04:57 PM
Pinhead's Avatar
New User
Default Re: highest compression w/stock b18c5 block (Reid)
no no no...I mean if i milled the head as much as it get be milled w/o clearance problem and a thinner gasket etc...
FSTASNTZ's Avatar
How are you going to raise or vary compression in any way if you cannot touch the block or head?
Jason
Old Mar 11, 2002 | 04:58 PM
Pinhead's Avatar
New User
Default Re: highest compression w/stock b18c5 block (FSTASNTZ)
I didn't say "block or head" I just said block.....
Old Mar 11, 2002 | 05:00 PM
FSTASNTZ's Avatar
I took the above as including the head and related surfaces along with the block.
Jason
Old Mar 11, 2002 | 05:01 PM
Pinhead's Avatar
New User
oops sorry...Yea that looks confusing I meant not touching the block BUT milling the head etc...
Old Mar 11, 2002 | 05:06 PM
FSTASNTZ's Avatar
The Spoon 2 layer gasket takes you to about 10.9:1.
Not sure how far you can take the head down. And even if I knew the amount, I am unsure of how each 10 thousandith effects compression...
Jason
Old Mar 11, 2002 | 05:15 PM
Tommy_Gunns's Avatar
How about putting in some CTR pistons? That would put you somewhere in the 12's I think (not sure, never done it).
88 EF Hatch
11
Jul 16, 2009 10:14 AM
RACING INTEGRATION
May 22, 2006 03:31 PM
Nisif
Nov 21, 2005 01:55 AM
servion
Feb 11, 2003 10:06 PM
