installing skunk2 tb help
Old Nov 16, 2005 | 11:09 AM
Linh.'s Avatar
Default installing skunk2 tb help
i am almost finished wiht installing my 68mm throttle body. All that is left is the house coming from the charcoal canister. Where does this hose go?
Old Nov 16, 2005 | 12:13 PM
Linh.'s Avatar
Default Re: installing skunk2 tb help (shooitslinh)
anyone?
Old Nov 16, 2005 | 11:37 PM
Linh.'s Avatar
help..
Old Nov 17, 2005 | 12:04 AM
tampabud's Avatar
It installs into the back of the head, where the original hose that came out of your stock throttle body was connected to... Hope this helps
Old Nov 17, 2005 | 12:42 AM
Linh.'s Avatar
Default Re: installing skunk2 tb help (tampabud)
no.. that hose was originally connect to the top of the throttle body. But the skunk2 throttle body doesnt have the connector at the top of it.
Old Nov 17, 2005 | 03:32 AM
tampabud's Avatar
Sorry for the late reply... the skunk2 throttle body does not have that hose connection because its a bypass, where the stock throttle body had 2 hoses coming out of, just connect your new hose to the back of the head, and the other side to the back of the intake manifold, I think the idle air control valve is where the other hose connects to... Good luck brah, I installed my Skunk2 TB about a month ago, its worthless in my opinion...
Old Nov 17, 2005 | 01:10 PM
Linh.'s Avatar
Default Re: (tampabud)
where did you mount the map sensor? i mounted mines on the bottom and the car and it wasn't running right so I blocked up that whole and just left the map sensor where it use to be. Also does your skunk2 tb make a whistling noise?
waynesumner
28
Feb 12, 2026 03:51 PM
cthumma
Apr 20, 2013 05:16 PM
camden
Sep 9, 2012 06:25 PM
1sikcoupe
11
Apr 8, 2008 06:50 PM
mortificationrock
17
Nov 13, 2007 06:49 AM
