how much would it cost for....
Old Nov 16, 2005 | 09:45 AM
honda95civic's Avatar
Default how much would it cost for....
valve adjustment
new rings
seals for where spark plugs are
replace clutch
head gasket and water pump maybe?
also.. my car is slightly buring oil and coolant..what could it be.. head gasket? water pump?
when i get on it.. smoke cuz barreling out.. blue and white combined i guess...
brand new clutch.. but the tranny chatters in 3rd.. and pops out of second so i bought another one.. cuz i think its the syrcros.. hope it solves the problem
but as for the cluth it is slipping.. (auto to 5 speed manual swap)
Old Nov 16, 2005 | 09:52 AM
Turbo_y8's Avatar
Default Re: how much would it cost for.... (honda95civic)
well if your burning oil and coolant sounds like head gasket
Old Nov 16, 2005 | 09:59 AM
Luserkid's Avatar
Default Re: how much would it cost for.... (tuck'd98)
The thing thats going to cost the most is the new rings install. Because that involves pulling the block appart.
Everything else you should look at around 500 or so of install. Depends on where you go. Also if your doing the water pump do the timing belt too.
Old Nov 16, 2005 | 10:00 AM
peacexisxfree's Avatar
you might as well put a new motor in your car unless you're planning on doing this all yourself. i asked a reputable honda mechanic how much he'd charge to do my rings and he estimted $1200 just because you have to disassemble everything. I'd say you're looking at about $1800 in labor only, but then again, i'm sure some smart *** will get on and tell you otherwise. this is just what i know from experience.
i think you should do a lot of research and do the work yourself. nothing you mentioned is that hard, unless you have absolutely no experience with working on cars. if the latter is the case, i suggest you not even try. either way, with parts and labor you're going to spend an arm and a leg.
what kind of car and what motor?
Old Nov 16, 2005 | 10:04 AM
Turbo_y8's Avatar
Default Re: how much would it cost for.... (peacexisxfree)
yea if its a d series you can pick up long blocks for like 500 or 600
Old Nov 17, 2005 | 06:26 AM
d16z6
i can do the head gasket .. as far as the rings.. i never did it before..
my brother in law owns a junk yard .. so i might wait till he gets like an integra or somethng and take that engine.. well see.. but thanks for the info..
LSteggyguy
18
Jul 21, 2018 12:07 AM
CaliforniaDad
Apr 15, 2012 11:44 PM
tony_yang
Honda Civic (2006 - 2015)
Jan 28, 2011 03:49 PM
PatrickGSR94
Aug 10, 2007 03:05 AM
Under Con. CrX
Apr 22, 2007 08:27 AM
