type R swap
Old Nov 16, 2005 | 09:31 AM
intech's Avatar
Default type R swap
i have a 98gsr, and just bought a 98spec type R motor from hmotorsonline.com....is that swap as easy as it should be? and are there anyother swaps i should do or anything needed to be removed or changed to work properly?
Old Nov 16, 2005 | 09:36 AM
98 Spec R's Avatar
Default Re: type R swap (intech)
Install the motor, axles etc...
Use your USDM GSR wiring harness.
Dont plug in: CKF plug on oil pump, VTEC Oil Pressure plug, IAB plug.
Plug in P73 ITR ECU
Start car
Good Luck it is a very easy swap.
Old Nov 16, 2005 | 12:06 PM
acuramike's Avatar
type r motor should bolt in . i say the swap can be done over a weekend or a day.plus the motor you picked very very very nice
Old Nov 16, 2005 | 12:10 PM
Kendall's Avatar
You will have exhaust fitment issues if you use the ITR header.
Old Nov 16, 2005 | 12:53 PM
fridayfred3p's Avatar
Default Re: (Kendall)
when you bought the gsr, did it come with an engine?
Old Nov 16, 2005 | 02:24 PM
Ichigo's Avatar
[quote]
when you bought the gsr, did it come with an engine? [quote]
looking in his sig. he has intake and header so i am assuming he has a motor in his car.
why are you going to do a gsr to type r swap?? Drop in some cams for your gsr and you would be fine unless the gsr motor is toast..
But should be a easy swap.
Old Nov 16, 2005 | 03:48 PM
Yoinked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">You will have exhaust fitment issues if you use the ITR header.</TD></TR></TABLE>
tis troo. i have a type r swap in my 98 gsr as well and the ITR header is too long for the gsr cat to fit right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r34lude &raquo;</TD></TR><TR><TD CLASS="quote">looking in his sig. he has intake and header so i am assuming he has a motor in his car.
But should be a easy swap. </TD></TR></TABLE>
nonsense type R's are gangster'er
Old Nov 16, 2005 | 04:05 PM
98 Spec R's Avatar
Default Re: (R34lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
There is more to the 98 JDM ITR than Just Cams:
Throttle Body
Intake manifold
LSD 4.7 tranny
4-1 JDM Header
Polished Cylinder Ports
Valve Springs
Higher Compression
Engine extra engine brace on the tranny/engine
ECU
Old Nov 17, 2005 | 10:19 AM
intech's Avatar
Default Re: type R swap (acuramike)
why would it be bad to install the wirring harness that comes with the new ITR? also will the DC sport header i have on my GSR motor right now bolt onto the itr?
Old Nov 17, 2005 | 10:23 AM
intech's Avatar
yes the stock gsr motor, bouht it with 80,000 miles, now it has 107,000 miles and is starting to burn oil. was thinkin of a rebuild but always wanted the itr. other than that oil burnin it runs fine and strong... while i had it i put a dc header, aem intake, and centerforce clutch.
Old Nov 17, 2005 | 10:26 AM
intech's Avatar
Default Re: (fridayfred3p)
i am going to bolt on the DC sport header onto the itr, that will work wont it? also the dualfriction centerforce clutch i have right now will work with the itr motor correct? also the stock axels will be fine correct? as you can see i have never dont this before....the only sawp i have done is a rotary egine in a rx7...so any info or other problems i may have that you know of would be a great help...
Pudge1421
K Series
Apr 16, 2018 05:23 AM
JayFI
Jan 8, 2013 03:03 PM
slimsdizz
Aug 15, 2010 08:24 PM
krazie1
Feb 22, 2005 03:30 PM
starbury
Jun 23, 2004 04:08 PM
