Knock Sensor help
Old Mar 11, 2002 | 03:39 PM
CRXSiR71777's Avatar
Default Knock Sensor help
I just put a B16 into my del Sol Si. I have a wire going from my ECU (d3 pin) to the knock sensor...am i missing something inbetween because im still getting a check engine light. Any help would be great....
Thanks much
Old Mar 11, 2002 | 05:57 PM
DragII's Avatar
25 Year Member
Default Re: Knock Sensor help (CRXSiR71777@aol.com)
more details....what year car/motor....and how exactly did you hook up the knock sensor wiring?
Old Mar 12, 2002 | 05:36 AM
I have a 93 del Sol Si. I took apart another wiring harness, put a new wire into my delsol harness into the ECU, i know its connected, and its in the right location. I ran one single wire into the knock sensor. one straight inline connection. Is there something that connects into the knock sensor somewhere? Is my Si del Sol prewired for a knock sensor and i missed it? I need some help. Thanks again.
Old Mar 12, 2002 | 03:21 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Okay, here's a few ideas:
RE-chip your stock ECU (P28) to run the B16A. It will run better than the stock B16A P30 ECU because the fuel and tinming maps will be better, you can have a higher redline (for when you get cams and valvetrain later), and you can have a better VTEC x-over than stock. IM user "kenji" here and he can tell you more. He re-chips the ECUs very good - I run one of his on my Type R motor.
Second idea if you're stuck on the P30 ECU:
http://hybrid.honda-perf.org/tech/info.html#B18EG6
Check that site for wiring help. Good luck!
Old Mar 12, 2002 | 06:04 PM
littlebluecrx's Avatar
Knock sensor wire should be sheilded, also make sure the actual wire is in the right
pin on the conector, if you are looking at the top of the connector the red/blue wire should be to the right if you are looking directly at the pins. it could just be off a pin fifty fifty chance if you did not use original connector, did you wire it direct from ecu to conector? If so check for continuity with a ohm meter from d3 to the pin if it is not there find the opening,Jason
surkitroller
Jun 3, 2005 06:42 AM
juiceman33
May 2, 2005 07:53 PM
mongoliandonuts
Apr 3, 2004 11:50 AM
