clutch/Tranny Problems...
Old Nov 16, 2005 | 07:00 AM
ITRiWISH's Avatar
Default clutch/Tranny Problems...
OK guys I need help bad!
To start with when i am in neutral and push the clutch all the way in it makes a whinning noise...
now i can barely shift it into gear... 1st, 2nd, 3rd... none of them see to want to work when its acting up... it seems that the only time i can shift is when the RPM's are perfectly matched. which is fine while excellerating... but down shifting is a crap shoot... i am lucky if i get 2nd gear... I may not be getting full disenguagement of the clutch...
the temp is dropping outside... i could also be loosing fluid somewhere but its been ranning here so i can't tell. For now i think i am going to replace the fluids and see if i can adjust the clutch...
oh yeah, I have a 95 Del Sol stock D series SOHC Si
Old Nov 16, 2005 | 07:28 AM
ITRiWISH's Avatar
Default Re: clutch/Tranny Problems... (ITRiWISH)
bump...
Old Nov 16, 2005 | 07:33 AM
BauleyCivic's Avatar
Risky Business
About the noise...thats probably a bearing inside the transmission. Either input shaft bearing, or another one of the mainshaft bearings. Read up more here: https://honda-tech.com/zerothread?id=596873
And then not being able to shift, my roommate had a similar problem and it ended up being a spring in the clutch. My only advice is to take off the trans, inspect the clutch/Throwout bearing and move from there.
Old Nov 16, 2005 | 08:08 AM
ITRiWISH's Avatar
well i hoping its simpler than that!
Any one else have any ideas???
Old Nov 16, 2005 | 08:48 AM
ITRiWISH's Avatar
BUMP
Old Nov 16, 2005 | 08:55 AM
djsire's Avatar
its not simpler than htat.
Old Nov 16, 2005 | 09:36 AM
Risky Business
Default Re: clutch/Tranny Problems... (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">its not simpler than htat. </TD></TR></TABLE>
This is correct. Welcome to the world of Hondas
B16/DelSol
Transmission & Drivetrain
Apr 21, 2011 03:37 PM
loco4sho2004
Aug 11, 2008 09:40 PM
Jeff C
Jun 20, 2003 03:43 PM
phatintegra
Mar 20, 2002 05:35 PM
SweetChin
Feb 28, 2002 02:41 AM
