What does EPS mean on your dash?
Went back this morning and whack the Map sensor. Reset the ECU. And did the idle reset thing. Where i ran the car at a consistent 3000rpm until the fan came on. Now the EPS comes on in the dash. What does that mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2GtizNUtz »</TD></TR><TR><TD CLASS="quote">Went back this morning and whack the Map sensor. Reset the ECU. And did the idle reset thing. Where i ran the car at a consistent 3000rpm until the fan came on. Now the EPS comes on in the dash. What does that mean?
isn't EPS the electronic steering system? Electronic rack and Pinion Steering?
</TD></TR></TABLE>isn't EPS the electronic steering system? Electronic rack and Pinion Steering?
Searched google and found this. It's refering to an NSX but the systems are pretty much the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by http://www.nsxprime.com/FAQ/Technical/eps.htm »</TD></TR><TR><TD CLASS="quote">
If a problem occurs, the control unit turns the system off by actuating a fail-safe relay in the power unit. This eliminates all power assist, causing the system to revert back to manual steering. A dash EPS warning light is also illuminated to alert the driver. To diagnose the problem, a technician jumps the terminals on the service check connector and reads out the trouble codes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K »</TD></TR><TR><TD CLASS="quote">EPS ... Eat , Poo, and Sleep
the light is basically saying, youre a lazy bastard
LOL
</TD></TR></TABLE>LOL
no no no that's only if you buy an 06 and enjoy the drive-by-wire. that's a lazy bastard.
what's a REALLY lazy bastard, is anyone who buys a new car because it has "rain sensing wipers". Why don't we just make toilets that wipe our asses?
</TD></TR></TABLE>no no no that's only if you buy an 06 and enjoy the drive-by-wire. that's a lazy bastard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 »</TD></TR><TR><TD CLASS="quote">JDM toilets spray your *** with a stream of water. You're old news man.</TD></TR></TABLE>
Those things are so ridiculous. Takes like 15 minutes to "wipe"! Plus if its laid on thick, I can't imagine the sprayers can get it all. It's like a Jeep that just went mudding going through one of those gas station pressure spray washes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Why don't we just make toilets that wipe our asses?</TD></TR></TABLE>
They do...if you have the money, you can afford to be as lazy as you want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp »</TD></TR><TR><TD CLASS="quote">
Those things are so ridiculous. Takes like 15 minutes to "wipe"! Plus if its laid on thick, I can't imagine the sprayers can get it all. It's like a Jeep that just went mudding going through one of those gas station pressure spray washes.</TD></TR></TABLE>
I heard the girls enjoy the front sprayers. Damn JDM freaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing »</TD></TR><TR><TD CLASS="quote">They do...if you have the money, you can afford to be as lazy as you want.</TD></TR></TABLE>
It's not just laziness. For older people, it's better to use a water sprayer to clean up than toilet paper, because it helps avoid hemorrhoids. I'm not making this up.
essex
Acura TL, RL & ZDX
Dec 19, 2004 02:15 PM
