blower motor-1993 honda accord ex
Old Nov 16, 2005 | 05:29 AM
hondawagon's Avatar
Default blower motor-1993 honda accord ex
blower motor failed
had new motor installed
now have no air circulation - defrost etc.
mechanic says vent system must be blocked (was not prior to motor failure)
mechanic wants to remove dash and clean vent system
big job! big dollars!
can you help?
Old Nov 16, 2005 | 08:28 AM
Ross 2.0's Avatar
In a Junkyard near you.
#1 is the new fan running?
#2 if it worked good before the fan took a crap the person that put it in may not have put it back together right. This is the one where you have to take the blower box out to replace the fan.
Baisically the mechanic that replaced it probably messed up. So make them fix it (free) and don't bothor cleaning the vents. They are trying to take you for a ride.
What I would do is take it to someone that knows what they are doing since this person obviousally doesn't.
Be sure to cuss them profusely.
Old Nov 16, 2005 | 10:46 AM
hondawagon's Avatar
Default Re: (MooGoCow3)
#1 fan is running
#2 blower box was removed
thank you for your reply
Old Nov 16, 2005 | 02:03 PM
P_Adams's Avatar
Default Re: blower motor-1993 honda accord ex (hondawagon)
If only the Blower Case was removed, he most likely forgot to plug back in #9 in illustration 3, or jammed up the doors it controls. If the system doesn't change modes IE: Vents/Vents-Floor/Floor/Floor-Defrost/Defrost, then look for a problem with #5 in illustration 2
#1) Evaporator Case Detail:
http://www.hondaautomotivepart...82%29
#2) Heater Case Detail: Refer #5 Mode Control Motor
http://www.hondaautomotivepart...+UNIT
#3) Blower Case Detail: Refer #9 Fresh Air/Recirc Control Motor
http://www.hondaautomotivepart...LOWER
TurboEM1
Acura TSX
Mar 5, 2012 05:52 PM
LT1
Oct 22, 2011 12:53 PM
mikeycivic
Mar 1, 2010 02:27 PM
092eg6
Aug 8, 2009 10:30 AM
Batchs
Sep 13, 2004 05:28 PM
