So, anyone attempted an Rx-7 shift buzzer in their car?
Old Nov 15, 2005 | 11:13 PM
O16581724 5 2 5's Avatar
Default So, anyone attempted an Rx-7 shift buzzer in their car?
I miss the sound of running my Rx-7 to redline and hearing that buzzer, since it's a parts car now, i have the buzzer still and no use for it. The engines redline about the same RPM, so, anyone attempted it and it work, or am i going to have to be the first and post a How-To, or the first to discover it fails?
I was also thinking about using uberdata's CEL shift light feature and just wiring the buzzer to that, not sure if the buzzer works off a certain voltage or if the Rx-7's ECU just sends a signal at a certain RPM.
No real point in this, so don't flame, just something to keep me busy, i do pointless little projects like this alot.
Old Nov 16, 2005 | 02:50 AM
gapergurlie_18's Avatar
sounds cool...do it and post pics
Old Nov 16, 2005 | 05:28 AM
TurboCoop's Avatar
Default Re: (gapergurlie_18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gapergurlie_18 &raquo;</TD></TR><TR><TD CLASS="quote">sounds cool...do it and post pics</TD></TR></TABLE>
yeah I also want to see a pic of a buzzer making noise... J/K --I know what you meant
Old Nov 16, 2005 | 05:29 AM
igo4bmx's Avatar
you could always power a relay with the uberdata cel shift light, which can power your buzzer with a full 12-14 volts if necessary
Old Nov 16, 2005 | 07:14 AM
Default Re: (igo4bmx)
Okay, i discovered the speaker is a part of the gauge cluster circuitry, i desoldered it and messed with the tach's circuit board trying to get it to work before discovering it's as simple as running a ground to it, running a resistor between the power and signal prongs and giving it 12vs.
A video of it in action! Let the page load completely and hit refresh.
http://media.putfile.com/20051116_110615
Old Nov 16, 2005 | 10:13 AM
Relic1's Avatar
reminds me of a $3.29 radio shack buzzer
http://www.radioshack.com/prod...17&cp
you can always build up the AICV control in your ECU and run the output of that to the buzzer. then you can set it to any RPM you want.
Hondaz_Son02
25
Oct 15, 2007 02:12 PM
DeDonDeRosa
Honda Civic (2006 - 2015)
17
Jul 15, 2006 09:07 AM
turboman
Oct 10, 2005 03:54 PM
Maxboost00
Jun 17, 2005 06:51 PM
rustboy
17
Mar 12, 2004 06:06 PM
