Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Sparco 3" harness, 2" wide bracket? Fit or not fit?
Old Nov 15, 2005 | 08:33 PM
migs's Avatar
Default Sparco 3" harness, 2" wide bracket? Fit or not fit?
The harnesses are 3" wide however the brackets that were provided have an opening for 2"
I will let the pictures do the talking. Sparco only makes one mounting kit which tells me its okay to kink the loop? Advice please...
Old Nov 15, 2005 | 08:35 PM
TeamSlowdotOrg's Avatar
Default Re: Sparco 3" harness, 2" wide bracket? Fit or not fit? (migs)
I know 3" brackets exist because I have some. I wouldn't do it if it were supposed to save MY ***.
Old Nov 15, 2005 | 08:37 PM
migs's Avatar
Default Re: Sparco 3" harness, 2" wide bracket? Fit or not fit? (TeamSlowdotOrg)
I forgot to add, the only PN that exists on http://www.sparcousa.com is 049101. Based off that, my guess would also be that maybe they superceded and started to use the smaller width.....cause its okay?
Old Nov 15, 2005 | 08:45 PM
Brett@SoloRacer.com's Avatar
What you have is correct. You need to fold both sides of the webbing over to feed it thru. See diagram #2 here for an example... http://www.gforce.com/pdf/harnessinstall.pdf
Old Nov 15, 2005 | 10:02 PM
Stinkycheezmonky's Avatar
Suspetise...
I have seen that done, but if it would make you feel more comfortable (it sure would make me feel better), try something like this: http://www.pegasusautoracing.c...=2999
Old Nov 15, 2005 | 10:52 PM
lastturn's Avatar
Default Re: Sparco 3" harness, 2" wide bracket? Fit or not fit? (Brett@SoloRacer.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brett@SoloRacer.com &raquo;</TD></TR><TR><TD CLASS="quote">What you have is correct. You need to fold both sides of the webbing over to feed it thru. See diagram #2 here for an example... http://www.gforce.com/pdf/harnessinstall.pdf</TD></TR></TABLE>
i was having the same problem. i have 3 inch belt with 2 inch brakets. you just answered my question too..
Old Nov 15, 2005 | 11:55 PM
Scotty Dosent Know's Avatar
Look at how the stock seatbelts are in your car they too fold the edges over
Old Nov 16, 2005 | 05:08 PM
BudMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamSlowdotOrg &raquo;</TD></TR><TR><TD CLASS="quote">I know 3" brackets exist because I have some. I wouldn't do it if it were supposed to save MY ***. </TD></TR></TABLE>
Interesting...I have 3" too. Funny, we have the same cage builder/harness installer
I wonder if he got separate pieces. I bought the harnesses myself, but didn't look at the pieces before I gave them to Jude.
Old Nov 16, 2005 | 05:20 PM
MattD@Stoptech's Avatar
That 2" bracket "looks" stronger than the 3" pegasus one.
Shrug.
Old Nov 16, 2005 | 05:33 PM
Andrie Hartanto's Avatar
the 2" is correct. The way to loop it in is to fold both edges. This way it strengthen the webbing and prevent tears.
Old Nov 17, 2005 | 08:55 AM
mstewar's Avatar
Default Re: (Andrie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie &raquo;</TD></TR><TR><TD CLASS="quote">the 2" is correct. The way to loop it in is to fold both edges. This way it strengthen the webbing and prevent tears.</TD></TR></TABLE>
that's the way they were designed to be used anyhow..
brzrkr
Apr 15, 2009 01:24 PM
SickIntegraWon
May 16, 2007 03:06 PM
erikiksaz1
Oct 10, 2004 04:39 PM
Hukd Up
Feb 19, 2002 08:57 AM
